101
Teltonika FM1100
Re: Teltonika FM1100
Hi,
Do you still need this FirmWare for the FM42xx ?   I have it for you ..
Skype me pls: hsrutgers
regards
Baltika
102
Teltonika FM1100
Hi,
No, thanks a lot.
Best regards.
103
Teltonika FM1100
reason is a faulty gps antenna shipment in january 2015. try to exchange gps antenna, than it will work again...
104
Teltonika FM1100
(edited by tonnorlando 03/06/2015 23:00:24)
Buenas
Hace un mes que venia con este mismo problema, en 8 equipos fm1100, comprado en febrero.
De a poco se corta la señal gps, y 0 satelites.
La solucion la encontre hace 4 dias, actualice el Firmware con la ultima versión que me ha
pasado Teltonika, y en los 3 fm1100 que actualice, se ha solucionado. Funciona normal
Firmware updater 1.10.17
105
Teltonika FM1100
Hello Wolf,
up today we replaced 5 GPS antennas and everything show that they were defective. Do you have any detailed info what was wrong with them?
Did you have similar problem? Did you open complain on GPS antennas to Teltonika?
Thanx.
106
Teltonika FM1100
Hello Tonnorladno,
on all FM1100 that show lost of GPS satellite connections we have firmware Ver:01.10.17 Rev:6. Even on FM1100 that are in vehicles connected to CAN BUS we installed firmware Code Ver:43.02.01. Unfortunatelly this problem was solved only after replacement of GPS antennas.
107
Teltonika FM1100
Some Times the antenna is not connected properly and it moves slightly from the main board of the device when the device are open for inserting sim or connect backup battery
Please check that too hope it helps mimicar
Regards
Yoosouf Parvez
From Startouch
Mobile : +23057631200
108
Teltonika FM1100
well, when i have read this thread and heard from Baltika that he also heard about this from some of his customers i just mailed our Teltonika sales Guy and asked him :-) Simple or?
I have no idea what was wrong but typicaly its some problem of cable/soldering etc...
Wolf.
109
Teltonika FM1100
Please don't blame Teltonika .
Just blam yourself for using Teltonika.
My experience.
Koby Karat
Ananas Global
110
Teltonika FM1100
Hi dear colleagues around the world,
Teltonika offers me to work with the new generation of FM 11XX (1110 & 1120).
Can you confirm me that the protocols and Port (20412) are the same we used already with the FM 1100 to connect to Wialon ?
Thank you guys,
Xavier
111
Teltonika FM1100
Xavier
yes, keep using 20412
Business Development Manager
112
Teltonika FM1100
Thank You wink
113
Teltonika FM1100
Buenas tardes, estoy intentando usar la salida 1 de un fm1100 pero no logro activarlo a través de wialon, comando tcp. alguien podría ayudarme con esto?
114
Teltonika FM1100
(edited by tonnorlando 03/07/2015 20:41:48)
Buenos días,
Estoy utilizando  el out 1, para el corte de motor y no logro activar o desactivar a través de la plataforma; solo me funciona a través de sms enviados por teléfono. Como hago para activar o desactivas desde la plataforma??
Gracias
115
Teltonika FM1100
(edited by milleniumpower 05/07/2015 08:23:24)
Hi everyboy
Actually am using Teltonika FM1120
I wanted help on, how to collect the drivers behavior data from the device in message ( wialon)
How to differentiate between the following  :
Harsh Braking
Harsh Acceleration
Sharp Turn
Sudden lane Change
and whatever else the device can provide
Please let me know in which Param to collect the data and how to split the data in sensors for later built the Eco driving rules
Awaiting your help thanks
Regards
Yoosouf Parvez
From Startouch
116
Teltonika FM1100
Also i dont understand any word of your text :-) i will try to answer you:
easiest way:
1.)deactivate sleep mode in FM11 and let the device send all 4 minutes a "hello here i am" message to Wialon.
2.) create 2 commands via TCP! with "setdigout 00" for deactivate DOUT1 and "setdigout 10" for activating DOUT1
3.) dont forget that DOUT1 is a open collector output = you dont have PLUS voltage at the output BUT GROUND if DOIUT=1, so you need to use a relais!!!
By the way, maybe you need latest firmware for the FM11... older Firmware does not support GPRS commands.
117
Teltonika FM1100
milleniumpower, with param253 (each non-zero value represent special event occured) you can create at least 3 sensors by using appropriate calculation table: harsh braking, harsh, acceleration and sharp turn.
Please let me know if you need further guidance.
118
Teltonika FM1100
Orlando is wondering about out 1 for Teltonika fm1100, for blocking the engine. The command is sent only via sms from the telephone, and is not sent from the platform.
119
Teltonika FM1100
tonnorlando, Make sure you have SMS package activated and you have SMS available. You can check it in CMS Manager. If you steel have doubts, feel free to write to support@gurtam.com
Tonnorlando, Asegúrese de que tiene el paquete SMS activado y tiene mensajes SMS disponibles. Esto se puede ver en CMS Manager. Si tiene más preguntas, siempre puede escribir a support@gurtam.com
120
Teltonika FM1100
milleniumpower, ok, did you activated eco-driving features in Features/Scenarios/Green Driving section of configurator. Are you seeing param253 in messages?
If this is light vehicle you can start with 0.3g for acceleration and 0.4g for braking.
121
Teltonika FM1100
And then, import attached .wlp configurations of sensors + eco-driving block into desired unit and test.
p.s.
Thanks Wolf for provided original file with calculation tables.
122
Teltonika FM1100
i Have uploaded it the wlp on the unit
will try tomorrow a let you know
thanks
Regards
Yoosouf Parvez
From Startouch
123
Teltonika FM1100
Hello again friends,
Since I cannot find any info on this, could someone explain the process or upload a manual, if one exists.
How would I make this work with FM1100? Any settings required in the configurator?
Cheers
124
Teltonika FM1100
Hi n.sehictz,
Did you try to ask Teltonika ?
regards
Baltika
125
Teltonika FM1100
Yes I did, but I have a feeling it will go faster here smile
