How to set Speed Limit in Graph
Topic: How to set Speed Limit in Graph
Hello Everyone
Good Morning
I have a question can i set speed limit detector in any units settings or in templates?
For example- i want to show speed in graph only if vehicle is moving with speed of 20km/h because i'm facing coordinate jumping in teltonika fmb125.
when ignition is off but vehicle is showing moving condition.so that i want to show only speed in graph greater than 20km/h .
Re: How to set Speed Limit in Graph
Hello,
All speed is usually shown in Wialon charts.
But it is possible to solve your issue, just follow the instruction below:
1. Create a custom sensor based on parameter "speed"
2. Set 20 as lower bound in calculation table.
3. Add chart to the report template
4. Add line "Custom sensors"
As a result you'll see value of the sensor that cuts off all the speed below 20.
@ Oleg Zharkovsky
Yes, you can typically set a speed threshold for data display in devices like the Teltonika FMB125, either through settings or templates in the software you’re using. Many GPS tracking systems allow you to configure filters or conditions to display data only above a certain speed, just like the Traffic Rider game just like managing data thresholds, players must carefully control their speed to avoid obstacles and maintain smooth progress. Both scenarios highlight the importance of setting clear limits to achieve optimal performance and accuracy.
You can set a speed filter in WIALON to only display speed data above a certain threshold, such as 20 km/h. To do this, go to the device settings (e.g., FMB 125), and configure the speed limit in the device or template settings. Then, apply a filter in the graph setup to show speed data only when the vehicle is moving above 20 km/h. This will help prevent showing erroneous data, like when the ignition is off but the vehicle appears to be moving. Test the configuration to ensure that only relevant speed data is displayed.
Nice!
"If you're looking to control speed limits in graphs, understanding the right parameters is key. Similarly, in racing games, having control over speed enhances the experience. If you're a fan of high-speed action, check out traffic racer pro mod apk] for an upgraded racing adventure with premium features!"
thanks!
luckygucci wrote:
Hello Everyone
Good Morning
For example- i want to show speed in graph only if vehicle is moving with speed of 20km/h because i'm facing level devil coordinate jumping in teltonika fmb125.
oh, useful!
