How to set Speed Limit in Graph
Topic: How to set Speed Limit in Graph
Hello Everyone
Good Morning
I have a question can i set speed limit detector in any units settings or in templates?
For example- i want to show speed in graph only if vehicle is moving with speed of 20km/h because i'm facing coordinate jumping in teltonika fmb125.
when ignition is off but vehicle is showing moving condition.so that i want to show only speed in graph greater than 20km/h .
Re: How to set Speed Limit in Graph
Hello,
All speed is usually shown in Wialon charts.
But it is possible to solve your issue, just follow the instruction below:
1. Create a custom sensor based on parameter "speed"
2. Set 20 as lower bound in calculation table.
3. Add chart to the report template
4. Add line "Custom sensors"
As a result you'll see value of the sensor that cuts off all the speed below 20.
@ Oleg Zharkovsky
