Re: Jimi JC100
Добрый день, коллеги.
Подскажите а где есть полный список доступных команд для JC200?
Вообще интересует как сделать блокировку двигателя, какая команда для этого нужна.
Спасибо.
Спасибо.
shaggiekeN
Set the petrol/electricity control RELAY,[A]#
A=0/1 0 means connection, 1 means cut off default: 0.
RELAY# Check the status of the control.
shaggiekeN
Спасибо Вам большое. Все работает.
А есть ли еще какой нибудь список команд кроме фото видео и блокировки?
shaggiekeN Concox GT06 не уверен что все команды подходят, но что то должно
I am running a Windows 10 Pro machine and cannot get the driver installer or the flash tool to work ...is it compatible with Windows 10?
Good afternoon, colleagues.
There is a JC200 device. Connected the device to WIALON.
I can not get parameter 1: SOS ALARM. Clicked the Alarm Button. But the parameter does not come.
Tried on two different devices.
molotok Please send all details to hw@gurtam.com (unit id, exact time when you activated SOS button)
I can not get parameter 1: SOS ALARM. Clicked the Alarm Button. But the parameter does not come.Tried on two different devices.
By experimental way we realyzed, that SOS button should be pushed during 8+ seconds...
We have no ideas about the reason...
I can´t update FW. The driver was installed correctly, but I have an error (Code 45) “Actually. This device hardware doesn´t connect to the CPU”. Then the SP_Flahs_Tool, can´t be used.
Can you help me?
Most US companies do not allow Flash to be installed due to security risks. There is no way for most US customers to view video if Flash Player is the only option. Changing the device preference to not be flash does not work. Please provide an alternative video player solution.
eron.iler At this time flash player is required.
We'll try to develop new video solution during 2020 but there are no any other details at this time.
WIFI,ON/OFF
To turn on/off hotspot
Video,inout,Xs
For X seconds video from both cameras.
As for automatic video upload, it's not automatic on carmatrix/tracksolid app with default fw.
Server is handling video upload requests (at least that is for VIbration alarm, i dint test other alarms yet)
Does anyone have link to download default jimmy fw for jc200 ?
Добрый день
Изменилось ли что в плане онлайн видео с данных устройств за эти пару месяцев?
Добрый день. Для jc100 и jc200 есть некоторая информация,а у меня на руках jc400. Знает ли кто нибудь как подключить его к wialon?При попытке отправить смс с заменой сервера,приходит ответ ERROR.
Разобрался,нужно поставить прошивку KMC28_JC400_WABA_CUST_V2.0.0_200826 Если кому-то надо,пишите в личку,есть подробная инструкция по подключению к виалон.
Disregard my previous request, I received the custom FW from Jimi Support.
>> Where can I find / download KMC28_JC400_WABA_CUST_V2.0.0_200826?
>> Где найти или скачать KMC28_JC400_WABA_CUST_V2.0.0_200826?
>> Thanks in advance!
Hello Team,
I have 2 JC400P and 1 JC400D, I need the above firmware and detail instruction to upgrade them because I have joined one of the devices to wialon but is not working, I am told I need the following firmware:
KMC28_JC400_WABA_CUST_V2.0.0_200826.pac -Use USB cable to upgrade
KMC28_JC400_WABA_CUST_V2.0.0_200826 -Use T card to upgrade
I will appreciate if anyone could send me the link to the above firmware.
I appreciate all your help.
Kwame
moli8552 Qual foi o comando sms que utilizou por favor?
What sms command did you use please?
