Topic: 1 Driver 2 Codes
Hello
is it possible to implement adding 2 codes for 1 driver, this will be helpful since We have some accounts that use driver id but with different trackers.
as you know the driver id code that being sent from galielosky devices is not as teltonika and other trackers.
so lets suppose that the first one will send the driver id as (code1) and the second one will send it as (code2).
right now i have to add the driver twice but with 2 different codes.
if the above were implemented I can add 1 driver with 2 different codes.
we can also use it if the driver has 2 tag
