151
WiaTag
Re: WiaTag
Hi GT
Would you please add a functionality to WiaTag (Android) to set it as Administrator application. This way we can prevent users to remove WiaTag using password.
152
WiaTag
Re: WiaTag
I have some customers complaining about the sudden stop of the wia tag app
the app suddenly stops sending position with every thing is on (location,network connection....etc)
right now they are handling this issue by pressing send position, when they press it every thing is back to normal
so is there is a remote way to make the phone press send position when its offline for more than a certain time?
a command or something else
153
WiaTag
(19/06/2019 14:30:31 отредактировано kopa)
Re: WiaTag
hasan.ahmed Yes, you can send the command "Query position" to the device (manually, by job, by notification's action, etc). But before please enable "Remote control" option at WiaTag's settings.
Mobile Development
154
WiaTag
Re: WiaTag
thanks, it worked perfectly
another question
i read the release notes of wia tag there was this update
Turning on and off the application service and crash report are added to the Status Messages
what are the  Turning on and off the application, crash parameters that is sent to the server
155
WiaTag
(22/06/2019 13:17:17 отредактировано hhamedk)
Re: WiaTag
Pavel Bushuyeu, any update regarding my request?
Hi GT
156
WiaTag
Re: WiaTag
i have the wiatag sending a position with Altitude, m = .....
what could be the reason?
157
WiaTag
Re: WiaTag
Altitude is one of GPS parameters in 3D positioning so it's normal that each GNSS module calculate it's Altitude.
158
WiaTag
Re: WiaTag
hasan.ahmed пишет:
another question
This is a quote from WiaTag documentation.
Service messages. When this setting is selected, the message contains the following parameters:
service status (s_on=0 — disabled, s_on=1 — enabled);
unforseen service shutdown (cr=1).
Sent messages also contain the parameter 'ls', the value of which depends on the selected location source
detector:
ls=3 — when GPS, Wi-Fi and mobile networks are used;
ls=2 — when Wi-Fi and mobile networks are used;
ls=1 — when GPS is used;
ls=0 — when location services are off.
Mobile Development
159
WiaTag
Re: WiaTag
i have wiatag installed on a Samsung tablet,
i deleted the iemi and created a new unit with the device iemi then i pressed send location several times the tables shows position sent message,but there is nothing in wialon.
i cleared the second unit iemi with zero messages received in wialon and created a third unit,same thing happened so i returned to the original unit and set the iemi to it.
after about 15 min the created unit received the messages that belong to it,after a wile the other unit(3rd) recieved the messages ,a and later the original unit recived the messages that it belong to it.
there was a time delay or shifting
any explanation
  • WiaTag
160
WiaTag
Re: WiaTag
hasan.ahmed please contact our support team (support@gurtam.com) and please attach WiaTag's log files.
Mobile Development
161
WiaTag
(24/12/2019 13:44:22 отредактировано kayaburcak)
Re: WiaTag
How can I find apk file of Wiatag ?
162
WiaTag
Re: WiaTag
We have found WiaTag becoming popular choice for customers since Coronavirus has seen many new potential customers needing a delivery solution, Logistics app, and this makes a great combination as it is less cost and not needing to purchase hardware and install.
Love the ability to send customers a QR code to activate too. Is there any chance that additional setting options could be added to this site instead of just basics?
Settings such as turning on "Additional parameters" when generating the QR code.
Currently we direct customers to a "How to" video we made showing them how to achieve this, it would be great to just do this for them when we create the QR code to send them to activate it. smile
Onwards and Upwards!!
163
WiaTag
Re: WiaTag
QR scanning is not available in the menu selection? How do I enable it?
164
WiaTag
Re: WiaTag
Hi
this should be available under ,
Settings > User Mods > Edit user Mode and go to the section " Main Screen" , tap on Actions , and you will see the list of available actions and enable enable "scan Qr Code"
Once done Click on Action button (+) button in main screen and you should be able to select "scan QR code"
Sint
165
WiaTag
Re: WiaTag
Azerbaijan Tourist e-Visa Requirements. In order to submit an application, eligible citizens are required to meet the Azerbaijan e visa requirements.
166
WiaTag
Re: WiaTag
Dear ryanebeerman,
i had the same problem and i tried all possible soultions.
the best one was activate remote configuration
create a notification with connection loss type for 1 min, the action of the notification was to send a command to the unit
the notification is (send position).
whenever the unit receive the notification it will sent the position right away.
to be sure that a position is sent i created up to 7 notifications
connection loss for 1 min, 2 min .....7 min
so if the first one didint work the other one will.
these notifications had a time limitation depending on their working time
167
WiaTag
Re: WiaTag
Hello,
I found one issue on iOS devices with OS 13+! The issue is that I cannot request a photo from the cameras ( tried all available options ) . When I install it on Android device everything works fine.
Can you please suggest what I should enable in order to fix this?
Kind regards,
Ivo Sinapov
168
WiaTag
Re: WiaTag
Hello,
ivo.sinapov пишет:
As I can in documentation for iOS (page 25) there is no possibility to query snapshot from camera in iOS.
@ Oleg Zharkovsky
169
WiaTag
Re: WiaTag
Hi,
Just a curiosity. Do Gurtam have plans to add "Query Videos" using commands in Wiatag?
Abraham
170
WiaTag
Re: WiaTag
Is this Topic still being used for Wiatag discussions?
Phoenix Solusi
Mobile Visible Secure
171
WiaTag
Re: WiaTag
Why do you ask? Do you want something?
