126
Teltonika FM1100
Re: Teltonika FM1100
Hi,
I doubt .......... because if you buy FM1100 and LV200 you also can ask for the manual...    Or did you buy at corner of street on a dark rainy evening ?
regards
Опубликовать вложения
Иконка вложений FM1100 with Light Vehicles Can adapter LV-CAN200 v1.1 (1).pdf 543.74 Кб, файл был скачан 1660 раз(а)
127
Teltonika FM1100
Imperium, te paso un enlace que contiene Manual, y algunas informaciones mas, ahi la puedes descargar  https://drive.google.com/open?id=0BwkND … TZzNjh5eVk
128
Teltonika FM1100
@Baltika, thank you for URL. I asked for manual, they ask "what vehicle will you be putting it in", so it's an unnecessary procedure. I know they need that info for specific connection scheme but I require the general manual, to understand the workings better.
And since there's no manual on avl1.teltonika.lt/downloads, I thought I'd ask here. @tonnorlando thank you as well.
129
Teltonika FM1100
Hello guys. I just got a teltonika fm1100 and i am struggling to configure it via usb cable.
For the usb config i downloaded some configurator tools from their website but i get this error:
"Configurator version does not correspond to FM firmware version. Software version like X.1.11.Y should be used to configure your device".
Ok so i understand that i need a certain version of the config tool. My device has Code ver: 01.11.07 and i cannot find anywhere this configurator version.
Does anybody else had this problem and has the recommended config tool?
Thanks!
130
Teltonika FM1100
Hi florin.stana,
This not a problem, just ask your supplier of your FM11xx unit ..
regards
Baltika
131
Teltonika FM1100
good luck with CANBUS reading :-)
We are still learning and trying since 3 years.
Without asking each time for each vehicle how to connect the correct canbus-wires (comfort can, motor can, dashbord can) you will not enjoy it!
Wolf.
132
Teltonika FM1100
did you get the problem solved?
Phoenix Solusi
Mobile Visible Secure
133
Teltonika FM1100
Hello everybody
I have a problem with Teltonika FM1100 configurator, it´s telling me that my firmware is not the right version.
But when I try to get the firmware file from Teltonika, they just keep directing me to the sales manager for my region,
which is not really interested in sending me the firmware file.
Does anybody have any idea on how can I upgrade my device firmware or where could I get the file?
134
Teltonika FM1100
Hi,
Ofcourse we have an idea how to upgrade the Firmware and where to get the file ..
Send me a PM
regards
Baltika
135
Teltonika FM1100
Did you solve the firmware issue?
Phoenix Solusi
136
Teltonika FM1100
Hello guys.
Does the gurtam platform support teltonika fm1000 obd2 device?
I can't find it in the avl page. This device also supports commands for reading/clearing fault codes (both sms and gprs). I am also interested if i can add a custom command in the unit properties for this.
137
Teltonika FM1100
Hi,
Protokol was the same as fm1100, so you can choose fm1100.
the implementation of fm1100 supports also sending of commands, its very good implemented.
Wolf.
138
Teltonika FM1100
Thank you, so i can also view in gurtam trouble codes from the engine right?
139
Teltonika FM1100
its send as list of parameters, you need to check the DOKU which parameter means what TDC
Wolf.
140
Teltonika FM1100
Hello guys.
I have a couple of cars with Teltonika FM1100 installed and connected to Gurtam Platform.
The problem is that in the reports, there is a big difference between the reported mileage and the car's dashboard mileage. I know that they will never be the same, but it seems with each day passing the difference grows.
I have setup the following methods for calculating mileage:
For each device i have setup one Relative Odometer Sensor with parameter: param199/const1000
and one mileage sensor with parameter: odometer/const1000.
For each unit i have selected Relative Odometer for the Mileage Counter and inputed the mileage from the car's dashboard and checked the Auto checkbox.
Also i have setup a Mileage Counter Job for these cars that runs every minute with the settings found in the attached image.
Please if you know any other setup so that the data can be more accurate, let me know.
Thanks!
141
Teltonika FM1100
Hi florin1
Can you please send us an access to that unit to support@gurtam.com?
142
Teltonika FM1100
You've got mail smile
143
Teltonika FM1100
Yes, we've got it. Can you also show us the "attached image" you talked about?
Technical Support Department
144
Teltonika FM1100
with correct configuration we have less than 0,3% difference between fm1100 with odometer and real vehicle odometer.
Wolf.
145
Teltonika FM1100
(20/01/2016 08:00:03 отредактировано fay)
Hi,
for TELTONIKA FM 1100 with available configurator always show the message "Configurator version does not correspond to FM Firmware version. Software version like X.8.5.Y should be used to configure your device"   I need supported configurator version or standard firmware and configurator
for Help Thanks a lot in advance My email is: lineofaction11@gmail.com
with Regards,
Ch.Gul
146
Teltonika FM1100
Hi,
Maybe contact Teltonika ?
regards
147
Teltonika FM1100
Baltika пишет:
Hi,
regards
Sir, Thanks for reply
Device is purchased from third person   no  information about reseller and any other who help me this is why  I am here and again request for kind help
Regards,
Ch.Gul
148
Teltonika FM1100
Hi Fay,
ask your Gurtam Sales Person for contact details from me, if you are a Gurtam partner/customer, i will help you with that.
Wolf.
149
Teltonika FM1100
wwbusch aka Buwo пишет:
Hi Fay,
Wolf.
Thanks for reply
Ch.Gul
150
Teltonika FM1100
Hi,
We often see a difference in mileage in cars who use other type of tyres than advised according the ""book"". Also tyre pressure can make a difference!
For example: one customer had a ""tuned"" VW Golf GTI, with special "'rubber shoes"" and we noticed difference from about 10 > 15 % !!!! .
Easy test: Take a GPS navigator, program a ride of exactly 100KM, drive this and check the difference between Odometer, Wialon, and navigator .
Problem is also that customers see the Odometer as reference, these values are ""true ""  in their point of view sad
regards
Baltika
