What’s new in Wialon
February 21, 2023
Updated search in the Routing tool
We’ve added the ability to use the unit location, geofence, or coordinates as route points. Previously, when planning a route, it was possible to search for points only by the address.
Error processing for third-party maps
We’ve arranged the processing of third-party map errors that may occur during the route building.
Language in Google geocoding
Previously, when using geocoding in the Address tool and other tools, the address was always in English. The language of the tools will now correspond to the user's language.
Highlighting problematic notifications
There are situations when notifications are sent an uncountable number of times for a huge number of units during a short period. It overloads the system and can cause the malfunction of other notifications. This issue can be solved by setting adjustments. To help the user immediately see problematic notifications, they will be highlighted in color and raised to the top of the list. An information window will also appear with a message about the issue.
Timer for Locator links
We created a link timer for the Locator page. Now, when sending a link that will start working in the future, there will appear a timer with the time when the link becomes active.
End time in marker tooltips
We complemented the parking, stop, start and end position marker tooltips with the end time of the event information. For example, you can instantly understand when the car left the parking lot and headed to the client.
Adding unit groups to automatic assignment lists for drivers and trailers
Now, you can create the automatic assignment list of drivers and trailers from unit groups. Thus, when creating a unit, you can add it to a group and quickly implement it into the work scheme if unit groups are used in the system configuration.
Tooltips for the Add Tab button in CMS
We keep improving the user experience in Wialon. Now, when you hover over the Add Tab button in CMS, a tooltip with the text "Add Tab" will appear. You can add five tabs. If you've already added all of them, you’ll see the tooltip "You can add no more than five tabs."
Sorting video files by columns in CMS
We added sorting by columns for the video tab to make its design similar to other CMS tabs. Now you can sort any column (except for buying packages) in ascending or descending order. It will allow you to quickly find the information you need, for example, sort the unit list by the number of purchased traffic packages and see which units will soon run out of traffic or storage.
Nastassia Maslovskaya
Business Analyst, Wialon
