Topic: Falcom Step II/III
Stepp III device that is connected to your server does not show the state of ignition. Device sends IO data through GPIOP line from which the rest of IO states are shown normaly. Can you answer that you read on server the first digit in the GPIOP line wich is IGN state. This input is IN7 and as such I have tried to setup but without success.
$GPIOP,10001111,00000000,12.05,12.05,12.13,12.13,12.23,4.13*74
Another problem is with Falcom RFID wich sends data via serial port and in wialon software is shown as STATE:xxxxxxxxxxx of the device.
Is there a way to join this recived data (aby some key word in front of data) with driver so we could use this option for driver identification?
Thank you in advance
