Topic: How to get fuel readings for Skoda Fabia Combi? [raw data is 0]
Greetings people! ![]()
This is my first post, I hope you will be gentle. I seem to be having trouble with fuel levels and consumption, not really sure how to configure it properly. The device is Ruptela FM-Pro4, and the car is the aforementioned Skoda Fabia Combi (2010).
Under 'Messages' in raw data, the fuel_lvl is always at zero and can_fuel_used is also at zero. The device is currently connected to the vehicle correctly, all of that is checked. I'm kinda new at this, so there's probably something I need to configure within the system (sensors or something else?), and maybe change the device configuration as well?
Thank you
EDIT: I'm now getting info that Pro4s are not really suited for regular vehicles, but mostly trucks... so if that's the case, this topic is kind of pointless. For now I will leave it here, in case I have problems when I replace the unit.
