251
AT65i
Re: AT65i
info-era пишет:
CAN: too many errors постоянно пишет что это?
не дает команду прописать постоянно выскакивает
252
AT65i
Re: AT65i
ребят помогите разобраться все настроил добавил а результата ноль хостинг не видит, может тчто не так сделал
AutoTracker Vehicle Device s/n:
SW Ver e4.9a1 ENT_P: Jul 17 2014 15:
http://www.autotracker.ru
Copyright (C) RNT 2005, 2006, 2007,
cmd> shvar
Show LOCAL VARIABLE:
Base position:          NON No GPS F
Current position:       NON No GPS F
Current speed (km/h):   0
Number of GPS satelits: 0
Accurancy (DOP):        0
Vector (grad):          0
Log ptr:                12
Log len:                2
Odometr (km):           0
Motor (sec):    0
GSM network:            MTS-RUS
GSM signal level:       8
GSM error rate:         0
Diag:           2
GPS echo:       off
Buff pos:       0
Rele stat:      00
GPS power:      off
SMS 8 hour counter:     0
SMS month counter:      0
SMS 8 hour counter notify:      0
SMS month counter notify:       0
Password:       aaa
Module GMT time:        NON
Time zone:       4
Is DayLight Saving:      0
Module Local time:      NON
OK
cmd>
*** Warn(42): CAN: too many errors
*** Warn(35): CAN: too many errors
ERROR:UNKNOWN COMMAND
cmd> shconf
Show CONF:
Diff:           100
Log Dist:       20
Log Dev:        5
Log Time:       0
Mask send:      0x00000000
Mask log:       0x00000000
Mask send ext:  0x0000
Mask log ext:   0x0000
Speed min/max:  10/140
Sensor 1:       off
Sensor 2:       off
Sensor 3:       off
Sensor 4:       off
Traffic interval:       20 sec to SM
Traffic per 8 hour:     255 SMS per
Traffic per month:      255 SMS per
Sat lost time:  300
Sensor refresh: 60
Master Voice:   1
Master Mode:    0
Guard status:   0
Guard type:     0
Guard sensor:   1
Guard rele:     0
Guard indicator type:   0
Radio Repeat Constant:  15      20
GPRS ID:        79127850633
GPRS DIST:      193.193.165.165:2052
GPRS APN:       internet.mts.ru:mts:
GPRS DIST2:     0.0.0.0,0.0.0.0,0.0.
OK
cmd>
*** Warn(29): CAN: too many errors
cmd> shvar
Accurancy (DOP):        0
Vector (grad):          0
Log ptr:                12
Log len:                2
Odometr (km):           0
Motor (sec):    0
GSM signal level:       8
GSM error rate:         0
Diag:           2
GPS echo:       off
Buff pos:       0
Rele stat:      00
GPS power:      off
Password:       aaa
Time zone:       4
OK
cmd>
cmd> shconf
Show CONF:
Diff:           100
Log Dist:       20
Log Dev:        5
Log Time:       0
Sensor 1:       off
Sensor 2:       off
Sensor 3:       off
Sensor 4:       off
Sat lost time:  300
Sensor refresh: 60
Master Voice:   1
Master Mode:    0
Guard status:   0
Guard type:     0
Guard sensor:   1
Guard rele:     0
OK
cmd>
253
AT65i
Re: AT65i
порт 20528 порт обрезался)
254
AT65i
Re: AT65i
хелп плиз я в отчаянии уже хочу  производителей промить к ним на хостинг както перейти чтоли
info-era пишет:
cmd> shvar
Accurancy (DOP):        0
Vector (grad):          0
Log ptr:                12
Log len:                2
Odometr (km):           0
Motor (sec):    0
GSM signal level:       8
GSM error rate:         0
Diag:           2
GPS echo:       off
Buff pos:       0
Rele stat:      00
GPS power:      off
Password:       aaa
Time zone:       4
OK
cmd>
cmd> shconf
Show CONF:
Diff:           100
Log Dist:       20
Log Dev:        5
Log Time:       0
Sensor 1:       off
Sensor 2:       off
Sensor 3:       off
Sensor 4:       off
Sat lost time:  300
Sensor refresh: 60
Master Voice:   1
Master Mode:    0
Guard status:   0
Guard type:     0
Guard sensor:   1
Guard rele:     0
OK
cmd>
cmd> shvar
Accurancy (DOP):        0
Vector (grad):          0
Log ptr:                12
Log len:                2
Odometr (km):           0
Motor (sec):    0
GSM signal level:       8
GSM error rate:         0
Diag:           2
GPS echo:       off
Buff pos:       0
Rele stat:      00
GPS power:      off
Password:       aaa
Time zone:       4
OK
cmd>
cmd> shconf
Show CONF:
Diff:           100
Log Dist:       20
Log Dev:        5
Log Time:       0
Sensor 1:       off
Sensor 2:       off
Sensor 3:       off
Sensor 4:       off
Sat lost time:  300
Sensor refresh: 60
Master Voice:   1
Master Mode:    0
Guard status:   0
Guard type:     0
Guard sensor:   1
Guard rele:     0
OK
cmd>
255
AT65i
Re: AT65i
в хостинге пишет что объект подключен но пишет что спутники не захвачены может есть какие-то нюансы о которых я не знаю????
256
AT65i
Re: AT65i
info-era пишет:
Дык, вам же сам прибор написал:
Антенну рабочую прикрутили?
257
AT65i
Re: AT65i
у меня подключен и модуль гланас и ещеи с самого прибора  антенна gps
258
AT65i
Re: AT65i
может есть какие то особые настройки для настройки gps или глонасс ?
259
AT65i
Re: AT65i
на wialon hosting терминал AT65i  пишет что на связи(горит зеленый значок) а координат не  видит на модуле глонасс диод мигает. если это форум еще актуален то прошу поделится опытом поставили прошивку  full8_4_9a.
и нужна ли  gps антенна если стоит модуль глонасс?
клиент просится на обслуживание с данными терминалами а менять не хочет их.
260
AT65i
Re: AT65i
andrius451 пишет:
Нужна обязательно. Из за этого у Вас все проблемы.
ГЛОНАСС модуль в АТ-65 это просто костыль
Симаков Алексей Арифович
navi-track.ru, glonass.center
тел.:+7-995-319-34-99
261
AT65i
Re: AT65i
Или отправить сообщение target_glonass  и блок будет брать координаты с доп. модуля по rs232.  Всех с наступающим!
262
AT65i
Re: AT65i
А какой командой отключить модуль глонасс?
Всех с наступившим.
263
AT65i
Re: AT65i
info-era пишет:
Всех с наступившим.
target_ent
264
AT65i
Re: AT65i
Добрый день. подскажите пожалуйста. что делать, Прибор прошиваю но после выключения питания и замены скорости обратно идут не понятные символы и не могу серийный прописать. и соответсвенно дальше тоже ни чего не идет
Есть может прошивки другие?
Всех с наступившим.
265
AT65i
Re: AT65i
прошивайте не меняя скорости
266
AT65i
Re: AT65i
andrius451 пишет:
lissd92 пишет:
Всех с наступившим.
Опубликовать вложения
Иконка вложений Full8_4_7b.whx 960.7 Кб, файл был скачан 799 раз(а)
267
AT65i
Re: AT65i
Спасибо что откликнулся. у меня после прошивки прибор не работает. Просто перезагружается через некоторое время. На боковине написано версия 8.3 а на печатной плате V7.03.
268
AT65i
Re: AT65i
Прочитайте весь форум и разберетесь у меня ушло две недели)))
в настоящий момент остановился на том что прибор передает данные, а после снятия питания и повторного включения перестает если кто знает причину ХЕЛП)))
lissd92 пишет:
269
AT65i
Re: AT65i
*** Warn(5): CAN: too many errors
*** Warn(36): CAN: too many errors
*** Warn(17): CAN: too many errors
*** Warn(48): CAN: too many errors
*** Warn(10): CAN: too many errors
*** Warn(41): CAN: too many errors
*** Warn(22): CAN: too many errors
что это значит???
270
AT65i
Re: AT65i
Разобрался. Только остановился на том что gps координат нет. После перепрошивки вроде заводится.  Но на сервер идут даные с одной координатой))) Причем скорость он фиксирует при движении но координаты той точки где прибор запустился. А после выключения питанию индикатор GPS даже не каких признаков не дает
271
AT65i
Re: AT65i
lissd92 пишет:
target_ent попробуйте команду для вкл GPS
272
AT65i
Re: AT65i
Base position:          NON No GPS Fix No GPS Fix
Current position:       27.01.2015 09:21:56 No GPS Fix No GPS Fix
Number of GPS satelits: 6
Accurancy (DOP):        2.2
Vector (grad):          13
Log ptr:                0
Log len:                0
Odometr (km):           0
Motor (sec):    0
GSM network:
GSM signal level:       0
GSM error rate:         0
Diag:           2
GPS echo:       off
Buff pos:       0
Rele stat:      00
GPS power:      on
Password:       aaa
Module GMT time:        27.01.2015 09:21:56
Time zone:       4
Module Local time:      27.01.2015 13:21:56
ребят подскажите чтот не так не могу добится вкл  gps
273
AT65i
Re: AT65i
andrius451 пишет:
Это "подарок" от разработчика - т.н. "3я галочка". Блок стучится на сервер РНТ и запрашивает ключ активации, в противном случае получает неправильное время и показывает координаты 2098 года. Код активации зависит от IEMI блока.
274
AT65i
Re: AT65i
koten пишет:
А откуда такая информация? У нас на предприятии уже очень много плат с такой проблемой. Зачастую у таких плат слетевший IMEI. После восстановления IMEI и разных перепрошивок, желательно со сменой версии базового сервиса, удалось оживить несколько плат (причем с GPS-модулем Leadtek, не с tsi). Насколько помню, при этом блок был не настроен на какую-либо связь с интернетом. Кстати говоря, очень много плат именно перестают работать просто так, т.е. в один прекрасный день перестают фиксироваться координаты (в админке они либо не определены, либо 2098 год). Техподдержка РНТ отмалчивается по этому поводу.
275
AT65i
Re: AT65i
В админке, у таких плат, на в кладке состояние в строке GPS стоят 2 галки, в нормальном состоянии должна быть только одна. Иногда помогает прошивка версии 4.4 (возможно в ней еще не было подобного механизма)
