Hi everybody!
This day, opening hopefully warm and sunny summer Gurtam Team is proud to present you a list of new features appeared today in Wialon Hosting.
The main idea for May was to commit to CMS Manager and implement there tools that will simplify the life for You, as manager of telematic business. We would like to invite You to CMS Manager and discover all these numerous new features by yourself, but here is just a short list of most important:
- sorting of all columns;
- resources/accounts modes are available with different set of columns;
- actuality column with last message time info for units;
- special Contents report fort accounts
- account column in all tables, Parent Account column for accounts;
- trash for restoring deleted items;
- hidden feature: for fast entering of payment just click on Balance or Days column of account;
- possibility to create subaccounts for dealers from without requirement of switching to them;
But CMS Manager is not the only one target for our first summer update.
Now it is possible to make special messages table in the report template. If you want to have Sensor values columns - use sensor trace report, if you want just messages with raw parameters - use messages trace report.
We modified Locator - now track feature show track for only last 24 hours and using the same technology as our mobile client - so tracks retrieval is really very-very fast. Also it is now possible to locate own position inside locator with magic button in right bottom corner of the window.
We finally managed with bringing LBS - GSM cell based location detection system - inside Wialon. So all you need is to activate special Allow positioning by cellular base stations in advanced settings of unit properties and viola - you’ll get LBS working for location detection when GPS is not available everywhere, including tracks rendering and reports.
For developers of alternative platforms we implemented interesting new feature in retranslation using Wialon Retranslator and Wialon IPS protocols - possibility to inject into messages values of know sensors - so that they can use powerful Wialon sensors calculations and receive for example ignition state or fuel level for tank in unified form from any type of device.
Special grouping mode - by shifts now is available in report templates. Shifts working time is specified report template settings.
Fresh reports for ecodriving and driver data analyzing from tachographs are now available fro drivers and driver groups as well.
We optimized Wialon monitoring web site. Now the load is 100% depends to the number of active units in monitoring panel and do not depend on total number of units available to user. With simple words it mean - now our largest customers with tens thousands of units can use monitoring site even better.
For sensors now it is possible to specify bounds after calculating sensor value - e.g. specify limits for fuel tank in liters, not in raw mV.
Wialon now support video-streams from devices, same way and in the same places as camera pictures supported.
And some new features, please read update announces to testing branch to get complete picture.
Wish you nice month and prepare for next update, that is already scheduled to june 29,
Gurtam Team.
At the
dark side of telematics...
