Тема: Idle Reports and Notifications
Hello
Is everyone able to get accurate notification and reports on Engine Over Idle violations which is Engine On while car not moving for longer than set period? There have been lots of wrong reports. Gurtam support has given me at least 2 types of notification configuration to solve inaccuracies but both have problem.
There are 2 scenarios where these types of notification becomes problematic:
1. No GPS, Yes GPRS. Normal ignition sensor -- Fail
Igor Custom Ignition -- OK
Alexander Speed Control on Custom Ignition- Fail
test 15 Idle Control on Custom Ignition -- Fail
(Example vehicle enters a building that has a gprs repeater but no gps)
2. No GPS, No GPRS. Normal ignition sensor -- Fail
Igor Custom Ignition -- Fail
Alexander Speed Control on Custom Ignition -- Fail
(Example vehicle enters building with no GPRS repeater and no GPS)
I checked back my emails to support and this idle report has been an issue since 2011 and there is still no clear solution. Ive had dozens of emails back and forth. The most recent test configuration was just the other day and its wrong wherein the idle violation notification continues even if there were no messages received from unit or even if an Ignition Off message has already been received. My customers are fuming. Does anybody have a tried and tested solution?
I think developers must try the approach of making immediately an Idles Report based on Messages. Then maybe a notification based on it.
Jac
