Topic: Include idling in ecodriving calculation
Hi
We have some bus companies that ask us to include idling analysis in ecodriving module.
Now ecodriving module is only considering travels, so idling infractions are done when gurtam already considers a stop, not a travel, so in ecodriving are not being included as violation.
I think that in ecodriving configuration you should include the possibility to "check" option: "Consider also in stops" so the parameter defined with this check would be analiced also outside trips (and could be attached to the last trip analyced).
On this way:
- if you dont need to analyce allways (not only trips), the load server time would be as fast as now, doesnt affect your servers.
- If you need to check "idling" parameter, the system would analice only travels + this parameter, so load time would be ok.
I atach picture of what I mean:
For bus companies and transport companies, idling violations is very important for them for ecodriving, as it affects a lot the total consumption of the company.
