Getting Geofences
Topic: Getting Geofences
Hello,
I want to know the best SDK method to use to get the list of registered Geofences (Core/Search Item By Property or Resources/Get_Zone_Data) under a certain resource. In addition, it will be great if it is possible to register a geofence under a certain geofence group via SDK and get list of geofences registered under a certain group.
Looking forward !
Getting Geofences
(edited by deal 13/05/2016 18:38:59)
Re: Getting Geofences
nasnew, do you use remote api or javascript api?
remote api
You can get all geofences from all resources using such request:
https://hst-api.wialon.com/wialon/ajax.html?svc=core/search_items&params={"spec":{"itemsType":"avl_resource","propName":"zones_library","propType":"propitemname","propValueMask":"!","sortType":"sys_name"},"force":1,"flags":0x00001001,"from":0,"to":0}&sid=sid
If you need to get geofences only under certain resources you can use such request:
https://hst-api.wialon.com/wialon/ajax.html?svc=core/search_items&params={"spec":{"itemsType":"avl_resource","propName":"zones_library,sys_id","propType":"propitemname","propValueMask":"!,your_res1_id,your_res2_id","sortType":"sys_name"},"force":1,"flags":0x00001001,"from":0,"to":0}&sid=sid
You can get all geofence groups including their geofences ids  for certain resource using such request:
https://hst-api.wialon.com/wialon/ajax.html?svc=core/search_items&params={"spec":{"itemsType":"avl_resource","propName":"zone_groups,sys_id","propType":"propitemname","propValueMask":"!,your_res_id","sortType":"sys_name"},"force":1,"flags":0x00100001,"from":0,"to":0}&sid=sid
To create/update geofence group and add geofences to it you can use such request:
https://hst-api.wialon.com/wialon/ajax.html?svc=resource/update_zones_group&params={"itemId":<your_res_id>, "id":<id_of_group_if_exists>,
                      "callMode":<create/update>,
                      "n":GROUP_NAME,
                      "d":DESCRIPTION,
                      "zns":[<zone_id1,zone_id2,zone_id3>],
                      "f":0}&sid=sid
More details and examples here:
http://sdk.wialon.com/wiki/en/sidebar/r … arch_items
http://sdk.wialon.com/wiki/en/sidebar/r … les/search
http://sdk.wialon.com/wiki/en/sidebar/r … t/resource
http://sdk.wialon.com/wiki/en/sidebar/r … ones_group
Also you can find useful examples and try your code on our playground http://sdk.wialon.com/playground/
Getting Geofences
(edited by nasnew 14/05/2016 13:43:38)
Thanks a lot
Getting Geofences
Hi,
I have system that fetch data from wialon and we use to have report in wialon generated and then fetched them with API calls to our custom app. It was working fine untill we have change in user. It appears wialon has complex structure in index and it got changed with user.
Any one please bail out as we are stuck as all api calls are falling deaf and we are not getting desired data.
Please have a look at attached file where we are getting unit name instead geofence and which is havoc in our existing system.
Regards,
Shah
Getting Geofences
(edited by nasnew 24/08/2016 14:40:31)
Please make sure you have created the proper access token for your new user, please refer the documentation regarding token http://sdk.wialon.com/wiki/en/sidebar/r … oken/token
Getting Geofences
Thanks for your reply,
I have checked my credentials.
it is fine still getting unit name instead of geofence name.
Please help me out..
I have attached screenshot for reference.
  • Getting Geofences
Getting Geofences
shah007, in Your report template final data in Geofences table there is Geofences/Units section.
Almost all geofences and all units are selected. Units in this section act as virtual geofences with specified radius (100 by default).
If You don't need to see visited units in report (only geofences) just uncheck units in this section.
Getting Geofences
Hi, Looking in to your attached screen shot, it seems like you have selected vehicles rather than Geofences when you create your Geofence report template.  please see the attached to better understand what I am referring to.
In addition when you create your user please make sure you have assigned your user with the privilege to create, read and update Geofence resource. (please check the second attachment ) or the user has the privilege to have access to the resource consisting the Geofences.
If all are ok i think it is better to check the API request you are making.
  • Getting Geofences
  • Getting Geofences
Getting Geofences
Thanks  for reply.
I have checked both the things. They are accessible but I can't get the geofence name in report.
Here I have attached screenshot for your reference
  • Getting Geofences
  • Getting Geofences
Getting Geofences
shah007, do You need only geofences in report result? As I wrote just uncheck units in report template.
Getting Geofences
Thanks @deal,
I have unchecked all units and checked the same but still displays unit names.
I have attached screenshots
  • Getting Geofences
  • Getting Geofences
Getting Geofences
(edited by deal 30/08/2016 18:23:29)
shah007, I've created copy of Your report template (final data) and unchecked all units in Geofences table and got only geofences in resulting report. Try it.
  • Getting Geofences
Getting Geofences
Hello,
Now,I am trying geofences report(area report) with custom template.But I can not data when execute report.
When I check with original template not custom template,data are receive.
My custom template is the following:
var template = {// fill template object
    "id": 0,
    "n": "unit_zones_visit",
    "ct": "avl_unit",
    "p":"",
    "tbl": [{
        "l": "unit_zones_visit",
        "c": "",
        "cl": "",
        "s": "",
        "sl": "",
        "p": "",
        "sch": {
      "f1": 0,
          "f2": 0,
          "t1": 0,
          "t2": 0,
          "m": 0,
          "y": 0,
          "w": 0
        "f": 0
Getting Geofences
For those trying to use it but failing in Dec 2021, there is an issue here:
flags must be set to a decimal number (4096) in this case, not binary 0x00001001 otherwise giving error.
Meanwhile 0x00001001 equals 4097 smile but on the documentation it is written that geofences are 4096 so
that should have been 0x00001000. ref: https://sdk.wialon.com/wiki/en/sidebar/ … t/resource
Maybe the api has changed since 2016 when this was replied...
My problem is although my request seems to work right now, it returns an empty geofence array:
My Request:
svc=core/search_items&params="spec":"itemsType":"avl_resource","propName":"zones_library","propType":"propitemname","propValueMask":"*","sortType":"sys_name"},"force":1,"flags":4096,"from":0,"to":0}&sid=xxxx
Response:
{"searchSpec":"itemsType":"avl_resource","propName":"zones_library","propValueMask":"*","sortType":"sys_name","propType":"propitemname","or_logic":"0"},"dataFlags":4096,"totalItemsCount":0,"indexFrom":0,"indexTo":0,"items":[]}
I'm sure I have geofences registered, I can see them in the web application.
I'm using a token generated for "Locator" application to get the session ID,
can this be the reason for that?
Thank you!
remote api
                      "n":GROUP_NAME,
                      "d":DESCRIPTION,
                      "f":0}&sid=sid
Getting Geofences
Yes, after checking out, I noticed that I had to enable Geofences from the FleeTrak AMS web app and now it returns Geofences just fine.
