ATalledo thank you!
Now I understand the core need for this request. I will add your request to the list of possible improvements in the future. Once there are any updates on that - I will let you know.
I want you also know that we have previously received request which may solve the problem you face at the moment. It was requested that when the option "Use geofences for addresses" is enabled - the address is not fully changed in the "Address" column, and both the address and geofence should be added as separate columns in the report. Let me know if that solution will suit your needs as well.
Also it may be helpful for you to try to use Geofences filtration for Trips table in the reports. Thus, there will be a column with address and filtration will leave only those trips which were in within the filtrated geofence. More you can read by following the link https://help.wialon.com/help/wialon-hos … filtration
К сожалению, у вас не достаточно прав для просмотра данного текста
Maryia Paklonskaya
Wialon Business Analyst
"The important thing is not to stop questioning" (c)
