Teltonika FMB640
Тема: Teltonika FMB640
Hello Everyone
Anyone using fmb640 device in genset monitoring?
Teltonika FMB640
Re: Teltonika FMB640
wow, you spam more than all these spammers together
eurosenstelematics.com
Teltonika FMB640
dont use it, it have problems that dosent have solutions till now
use fmb202 its much better
Teltonika FMB640
hasan.ahmed пишет:
how can you compare fmb640 with CAN bus, rs485 etc with simple location tracker like fmb202, so different applications and markets.
Teltonika FMB640
he didint mention canbus data and rs485
he can use galielosky instead if he need tings like that
Teltonika FMB640
mechatronicaHello
I just wanted to know
Case1
can i use fmb640 device in Gensets if Gensets has rs485 port or if dg has 3 phase and fmb640 has also 4 analog inputs so can i get kWh of dg using fmb640?
Case2
If there is no rs484 port in the DG , can I connect the energy meter and take the data  through the fmb640 device
Teltonika FMB640
nowucsm пишет:
mechatronicaHello
Case1
Case2
Sorry, I have to give up. You don't have a basic knowledge about the device interfaces, so I cannot explain you anything.
Teltonika FMB640
I had experience of FMB640 where I faced so much instability with the GSM modem and its BT module. Ended up completely replacing it with FMC130+LVCAN200
