Topic: Teltonika FMB640
Hello Everyone
Anyone using fmb640 device in genset monitoring?
Hello Everyone
wow, you spam more than all these spammers together
dont use it, it have problems that dosent have solutions till now
use fmb202 its much better
how can you compare fmb640 with CAN bus, rs485 etc with simple location tracker like fmb202, so different applications and markets.
he didint mention canbus data and rs485
he can use galielosky instead if he need tings like that
mechatronicaHello
I just wanted to know
Case1
can i use fmb640 device in Gensets if Gensets has rs485 port or if dg has 3 phase and fmb640 has also 4 analog inputs so can i get kWh of dg using fmb640?
Case2
If there is no rs484 port in the DG , can I connect the energy meter and take the data through the fmb640 device
mechatronicaHello
Case1
can i use fmb640 device in Gensets if Gensets has rs485 port or if dg has 3 phase and fmb640 has also 4 analog inputs so can i get kWh of dg using fmb640?Case2
Sorry, I have to give up. You don't have a basic knowledge about the device interfaces, so I cannot explain you anything.
I had experience of FMB640 where I faced so much instability with the GSM modem and its BT module. Ended up completely replacing it with FMC130+LVCAN200
