Topic: Gurtam Map Speed limitations Layer
Hi GT
Wialon has possibility of detecting speed limitations from Gurtam Map. It would be great if you add possibility of viewing these data as a Map Layer (like traffic layer) on Gurtam map in a way that user can activate it or deactivate it. As I guess you will say such layer has huge load on Gurtam Map I have two offer for solving that:
1. You may read these data from Gurtam map for all countries and update the layer once a month.
2. At least you can change the Address Tool to Reverse Geocoding Tool and add possibility to that tool to show not only address of chosen point on map but also speed limitation of nearest way to the point in appropriate field. In this way there won't be any heavy request on Gurtam Map and user has possibility to check if the speed limit is correct or not and in case of incorrect speed limitation can simply ask you to correct it.
