Hello Thomas Thomas RoadLink,
Thank you for the screenshots - it is immediately clear what your request is about.
First of all, I want to give a small comment on determining the state. Different algorithms and mechanisms are used to determine the state of movement in Wialon Hosting and in the mobile application. At Wialon Hosting the motion state is defined on the basis of speed information in the latest message or a real-time motion sensor. The mobile application determines the status on the basis of the received events (trip, parking) and knows exactly when and what event started. In order to receive and display information about the start time or duration of the event in the unit extended information, it is necessary to change the approach to status determination. For this reason, it will not be possible to make such changes quickly.
I would also like to ask you a few questions:
1. How do you use this information?
2. Why is this useful for you and your users?
I have put your proposal on the list of suggestions for the development, but so far with low priority. The situation may change if more partners support your idea and add some cases from real life when such tags help to solve a particular issue.
Nastassia Maslovskaya
Business Analyst, Wialon
