Topic: Distance Tag
Here we may share information about app, discuss use cases and solutions, ask questions.
Wanted to share beacons that some our partners use with app.
https://ozrobotics.com/shop/bluetooth-5 … -solution/
https://www.alibaba.com/product-detail/ … 3401RY5H3a
https://www.global-tag.com/portfolio/bl … p-sensors/
https://buyibeacons.net/bluetooth-low-e … t-ibeacon/
https://www.oemblue.com/beacons/Bluetoo … tband.html
https://mango-rfid.com/wristband-beacon … ional-nfc/
when the webinar will be published on you tube, i fall asleep and missed it
Hello Oleg
I thinks that your application Distance tag is a first step interesting for Covid19 . I would like to suggest an extension to avoid some Distance Tag contraint and possibility to access big market ( you know may be that a consortium is working for a tracking solution for government in Europe )
So with Distance tag contraint are :
1) each people need to have is own smartphone and pay communication ( 3G or 4G) fees ( not so easy for old person)
3) the battery discharge could be a big trouble ( Wiatag experience)
2) even it is easy you need a admin app and configure each smart phone with the Bluetooth Tag
I would like to share with you another concept
1) each people has a Bluetooth Bracelet ( Low cost)
2) an Android tablet with 3 or 4G connection has your special app with the ability to scan all Bluetooth bracelet around ( Up to 100 if possible)
This android tablette is always powered so no trouble of power . This android tablet is in a place like a confinement area ( Hotel , Hospice, Hospital) and also in main shop of the town and why not in each bus .....This android Tablet is connected to Wialon as a special device ( an GPS Hub for bracelet )
4) we create each people like an objet by sending a list of ID of Bracelet on Wialon
5) So each people could be located in some special place or out the place so it is easy to detect place where some people are in contact and see if people with contamination has been in contact with other people
6) reception of a big number of tag by a GPS device was already done in Wialon for special project
I will be interested by your feed back and all partner interested by this market
can i connect it to more than one bracon?
or set it to connect to the closest beacon from 4 beacons?
Hi, can you describe your case?
well lets say i have a person and 5 different places, and inside each place there is a beacon
if this person is disconnected from all the 5 beacon i should be notified, if its connected to any beacon then there is no problem
Currently Dtag was designed to tie the wristband/beacon that is on a man with the smartphone. So it is possible to pair only one beacon.
But in future, we will think about a solution with multiple beacons.
