Тема: Fuel Consumed Columns Summary/Statistics
Hello,
We used to control vehicles with FLS in other platform, but now we have started using inside Wialon.
The equipments are Omnicomm Optim and Fuel Level Sensor LLS4.
The first thing we realized was that the values of fuel consumed wasn't matching in both platforms, the reason was simple: Engine Hours and Trips reports were only calculating the fuel consumed in the periods of trips or engine hours. The difference was almost 15% in volume in some cases, this is a lot because these sensors have high accuracy.
Using the report Summary, every information were coming right, but it doesn't have columns like Engine Hours With/Without Movement and the Fuel Consumed With/Without Movement (these last columns exists in Statistics tables). The fuel consumed from this report is the most accurate for us and you can see by comparing the fuel consumed with the fuelings.
Also, it would be great if we could have the calculator inside the Statistics table because here in Brazil we use km/l instead of l/100 km and without it, the only average we have is from trip reports.
Technical Support, Rastreasul
fernando@rastreasul.com.br
