Тема: REnder error explanations
Hello,
Can you send me info where I can check errors regarding this?
WialonError(Unknown error render_create_messages_layer (6))
thanks
Hello,
thanks
Hello!
Access denied often means some issue in access rigths in hieraryr or with billing services
So try to check access ritghts for users in hierary, also tokens rights
Also please check time parameters ("timeFrom" ,"timeTo") in request, they should have valid value
Hello,
rights are correct over the token.
client informs they use: timeFrom=1574964526&timeTo=1574964560
thanks
Hello,
rights are correct over the token.client informs they use: timeFrom=1574964526&timeTo=1574964560
thanks
Please provide via PM full example of requests : login (token value), then full request create_messages_layer
ok, i ll get them
thansk
