REnder error explanations
Topic: REnder error explanations
Hello,
Can you send me info where I can check errors regarding this?
WialonError(Unknown error render_create_messages_layer (6))
thanks
Locating things
Re: REnder error explanations
Hello!
Access denied often means some issue in access rigths in hieraryr or with billing services
So try to check access ritghts for users in hierary, also tokens rights
Also please check time parameters  ("timeFrom" ,"timeTo") in request, they should have valid value
Diana Cheley
Wialon Hosting Expert
Hello,
rights are correct over the token.
client informs they use: timeFrom=1574964526&timeTo=1574964560
thanks
Locating things
locationGPS wrote:
Hello,
thanks
Please provide via PM  full example of requests  : login (token value), then full request create_messages_layer
Diana Cheley
ok, i ll get them
thansk
Locating things
