Drivers and Geofences Reports Changes
(13/09/2019 14:23:21 отредактировано Fernando Brochetto)
Тема: Drivers and Geofences Reports Changes
Hello,
We’ve created a lot of reports inside Wialon in our admin user and we enable the access of the reports from admin to every user. We work in this way because we want that every client have reports updated and a lot of them.
1. But we have a problem with reports of drivers and group of drivers reports: these reports works only for the clients users if the reports are created inside their users.
2. The same thing happens with geofences reports: when a report created by admin is executed by a client, the geofences reports doesn’t appear. Another thing that is a problem is that when a new geofence is created, we need to edit the report and select every new fence to be enable inside all the reports. I think that could have an option if any geofences weren’t selected, the report should be executed as if every geofence was selected.
Is there any way to change this?
  • Drivers and Geofences Reports Changes
Fernando Brochetto
Technical Support, Rastreasul
fernando@rastreasul.com.br
Re: Drivers and Geofences Reports Changes
A resource is a macro-element it works like a container for drivers, geofences and reports. That is why the work between different containers is labored and it is not possible to use a report template from one resource and driver from another.
Read more about object types in the documentation.
Tatsiana Shmihelskaya
Business Analyst, Gurtam
(17/09/2019 15:46:57 отредактировано Fernando Brochetto)
Hello tata,
Got it. Do you think it is possible at least to change this?
In this way we could just import the report to the client without the need to select all geofences every time, and also if the client use to create a lot of geofences, would be easier for him to create the reports he should want.
Fernando Brochetto
create a group of geofences (called A) and add all geofences that you want to it,  change the setting of the report to make it work only on group A.
any new geofence should be added to the group and the report will work perfetly.
