Topic: Geofences speed limits
Hi
is there is a possibility of adding a speed limit option in the setting of the geofence?
we can use it as a new option for speed detection in addition to the 2 cases of speed detection (in advanced field).
furthermore if the car was inside a geofence ( with no speed limits for this geofence ) or outside all geofences (with speed limits) it will use one of the other options for speed detection.
for example use fixed speed limit is set to 80 km/h and there is 5 geofences with different speed limit for each one of them, if the car was inside one of the geofences the report will take the speed limit from the geofence. if the car was outside these geofences the report will work with the default speed limit which is 80.
just like use geofence for address in the address setting of the reports
if there was a drawn geofence the report will display the name of it, otherwise the name of the place on the map will be displayed.
thanks.
