Troubleshooting of the fuel level sensor data
Тема: Troubleshooting of the fuel level sensor data
We have made some videos about typical troubleshooting of the fuel data (level sensor).
Hope it will be helpful.
Part 1. No sensor data
Part 2. Bad data
Subscribe to our channel
eurosenstelematics.com
Re: Troubleshooting of the fuel level sensor data
hello sir
good morning
we install digital sensor in street sweeper machine , issue is that when machine ideal and work using only back machine machine for cleaning some garbages a theft report generate automatically but report are not actual , so how can i sort this problem   please reply
Hello,
nowucsm пишет:
If I understand you right, you have both vehicle engine and sweeper machine as a fuel consumers, while only one fuel tank is used. So you should have 2 engine ignition sensors and both of them should be binded to the FLS. Also don't forget to type consumption value for both ignition sensors and use time-based calculation in FLS.
Please contact support@gurtam.com and share more details about the issue, if my recommendations won't work.
@ Oleg Zharkovsky
