Import configuration from wlp file API
Topic: Import configuration from wlp file API
I want to copy the configuration of a unit to other units by means of the API, I have seen that there is a method to export the WLP file exchange/export_json&params={"fileName":<text>, "json":{}}  and a method to import itexchange/import_json&params={"eventHash":<text>}
I have doubts as to how to pass the id of the unit that i want to copy the configuration.
I use the api with php
Anyone has used this method?
Thanks
Re: Import configuration from wlp file API
Hello
Check this topic https://forum.gurtam.com/viewtopic.php? … 00#p145000
