Topic: Import configuration from wlp file API
I want to copy the configuration of a unit to other units by means of the API, I have seen that there is a method to export the WLP file exchange/export_json¶ms={"fileName":<text>, "json":{}} and a method to import itexchange/import_json¶ms={"eventHash":<text>}
I have doubts as to how to pass the id of the unit that i want to copy the configuration.
I use the api with php
Anyone has used this method?
Thanks
