Speed limit in geofence
Topic: Speed limit in geofence
I have client has many geofences and each geofence has speed limited . he need to know which unit is entered his geofences and moved more than speed limited for example if the unit enters the geofences it's speed limit =80 kmp
and a unit  moves with 85 at time 10:10:00
and moves with 90kps at 10:10:12
and moves with 95   at 10:10:22
he needs those three speeds with it's time
help  please
Re: Speed limit in geofence
You should try to use several tables "Geofences" with intervals filtration by different speed value.
E.g. first table should control speed range 85-90 kmh, second should control speed range 90-95 kmh, etc.
(Don't forget to activate option "Retrieve intervals" in intervals filtration.)
@ Oleg Zharkovsky
my customer need all geofences with speed limited in one table.
You can create several different notifications with speed control in geofences. Notification action should be "Register event for unit" or "Register as violation". Output of such notifications can be displayed in one table "Events" or "Violations".
If you use events/violations registration as action for other notifications also, then you can filter only the needed events with a help of text/description mask.
@ Oleg Zharkovsky
