26
Video monitoring in Wialon
Re: Video monitoring in Wialon
Gotyou If both devices send data to server separately -- it's impossible to make 1 unit.
May be, tracking device (like Calamp) can  be connected to MDVR (like Streamax). For example, Calamp sends telematics data to streamax via RS232/485  and  streamax sends data to a server -- it's possible to have 1 unit with video and parameters. It's better to ask manufacturers of the devices.
For example, we know that Calamp can be connected to Servision MDVR. But we've never tested the exactly functions
Viktor Yarovenko
Business Analyst
Wialon
27
Dear Gurtam team,
The option minimapa more like the customers.
I have to add that in addition to the video, could also include the snapshots (images) that a device sends to the server.
I have customer queries that use Smartwitness KP1 that have asked me about this possibility.
Greetings.
28
instantconnectibiza,  thanks for your proposal. We will have in mind it in further development. If it possible we will add such a functionality.
Tatsiana Shmihelskaya
Business Analyst, Gurtam
29
I have another question. Normally the mdvr points to a dedicated video server that will allow detailed analysis of the video files on a video analysys tool like  CMSV6. Typically also the video footage can be downloaded via 3G to view. If the mdvr is pointed to Wialon server how will the histroric data be viewed and downloaded. I am not sure how this will work. Can a member of Wialon team explain this to me. I hope my question make sense.
30
Gotyou, it depends on the device you use. Live stream is not stored in Wialon. And episodes in the past required by the command are stored. Some mdvrs have such options, some don't.
31
can I make a sKype call to you to discuss this issue?
32
Hi there
Is it possible to add a function to bind a MDVR to a unit? let me explain, when we are talking about MDVRs, most of them don't support advanced functions like CAN data reading or FLS sensors connection. If we want to have such advanced data on one vehicle we have to create 2 unit for each vehicle and it not only cost but also it's not convenient. My idea is that if we want to offer customers video surveillance plus advanced FMS  functions we can create an unit with an advanced device like BCE Blue+ and then bind a MDVR without GPS function to this unit. this way we have all data from BCE plus video files or live streaming from MVDR in same time. What you think?
33
Hi Gurtam team
     I'm testing 1 unit of Hero-ME41-04 on your hosting (beta) and have questions below.
1. The detail of parameters.
    Could you share the detail of device parameters? (attached Hero-ME41-04-Parameter.png)?
2. Cannot download VDO.
     According to the specification of VDO download command that the maximum of duration is 20 seconds.
I found that the VDO could not be downloaded if I set the duration more than 16 sec. I'm not sure it is the device problem or software bug. Could you please check?
3. Online VDO monitoring
    It seems the function "Online VDO monitoring" for this device type does not finish yet. Could you tell me a rough schedule when you will finish it?
Regards,
Mr.Teera Koedchan (Mobile Innovation Thailand)
  • Video monitoring in Wialon
Mr.Teera Koedchan.
Developer, Mobile Innovation (Thailand) Company Limited
“We contribute to society by delivering SECURITY and SAFETY to customers”
34
Any response on my last post under this topic?
35
hhamedk We know that Servision video devices support connection to Calamp trackers.
Haven't tested this solution in Wialon yet.
But if you are intrested in it, please clarify the detailes about your project to hw@gurtam.com
We can discuss testing process and integration more detailed.
Thanks.
Viktor Yarovenko
Business Analyst
Wialon
36
(25/09/2017 10:32:25 отредактировано yavi)
teerak
1)  We'll  place parameters' description on our website soon
2) Life stream video recording 1-20s should work. If you ask about downloading video from internal memory, please check Timezone settings (in minutes) in the addtitional properties of device type Hero (a wrench icon near device type)
Please write hw@gurtam.com (including information about your unit id) and we'll check your problem
3)Life video stream (without recording a file) isn't supported and it can't be implemetned in the nearest future
Viktor Yarovenko
Business Analyst
Wialon
37
(26/09/2017 08:21:27 отредактировано teerak)
Hi yavi,
     Thank you very much for your reply. Sorry for the question doesn't clear.In 2) I mean downloading VDO from internal memory.
The Timezone setting is same (+07:00 in a device, 420 min in device setting on hosting). I already wrote an email to HW team with necessary information.
Regards,
Mr.Teera Koedchan.
38
Looking forward to the mini map
39
teerakWe've found the error and fix it.
Please, check
P.S. We've added parameter description
https://gurtam.com/en/gps-hardware/auto … parameters
Viktor Yarovenko
Business Analyst
Wialon
40
Hi yavi,
     Thank you very much for the parameter description and bug fixing.
I tested and the problem still happens. I already wrote an email to HW team.
Another question, What is "BD" stand for in location type?
Best Regards,
Mr.Teera Koedchan.
41
teerak Let's continue via email
Viktor Yarovenko
Business Analyst
Wialon
42
yavi пишет:
Tim.Mwandha We plan to  integrate Teltonika MVC300 camera soon.
Integration will be finished in September (approximately).
The list of already integrated devices (with external camera) you can find here:
https://gurtam.com/en/gps-hardware/auto … %5D=camera
Is there any updates about MVC300 camera integration ?
43
(10/10/2017 14:45:57 отредактировано yavi)
montasser we're working on the integration.
We hope to finish it soon (picture transmition).
Viktor Yarovenko
Business Analyst
Wialon
44
U can use another app https://mobile-spy-apps.com/ mobile recorder on Android.
45
para cuando estaria la intregacion de videos en vivo , para los equipos howen y smartwitness
46
buenas, para smartwitness no esta prevista la intregacion de videos en vivo, funciona a traves de los comandos asi como esta realizado ahora,
referente a howen si, estamos en el proceso de integracion, siga las noticias
47
Hello,
Looking at how media is downloaded and saved.
we would like the media to be saved using the unit name as opposed to the code that appears while saving.(see attachment)
it is hard to identify media if you do not remember the unit name.
Can the system capture the unit name automatically as we save the media?
48
Hello, ellyM.
Unfortunately, current structure doesn't let us change file names.
We have plans to make some changes and to appreciate your request if it is possible.
49
Hello,
Please consider setting up jobs for media reports. At the moment it is not possible so i was advised to write it on the forum.
50
emphielly, could you send me more details in private message, e.g. username and problematic report name? Not sure if it is an improvement or a bug or just wrong settings.
