Re: Testing: "Passengers" module (School Buses)
jhdeguate, ok, we'll add groups of passengers but not right now.
Could it wait please?
No problem Sir! I will be waiting for that feauture to be added...
Thanks a lot...
Thanks a lot...
Passengers module is constantly being improved to move beyond school buses monitoring. It’s currently used to track employees to track employees 24/7. Here automatic unbinding at 00:00 is no more applicable. That’s why in Wialon Beta we implemented automatic unbinding 10 hours after passenger pick-up. If this happens, you can see “automatic unbinding” mark in passenger history. The update helps to eliminate pretended passengers remaining inside a vehicle for days, weeks, years... Moreover adequate passenger unbinding improves the accuracy of data in reports and statistics.
Considering the increasing popularity of Passengers module we are on our way to completely integrate it into the system. This time Wialon Beta acquired updated “Search on Map” tool, allowing for dynamic search by passengers. Upon clicking on the target passenger the map is automatically scaled and centered on the unit transporting the passenger or a drop-off point.
Thus, knowing a single passenger name, you can easily find the relevant transport vehicle. Moreover, you get visualisation of passenger location with no need to study statistics and reports.
Passengers are now represented in one of statistical reports. Resource contents report in CMS Manager contains data on passenger quantity. That way you get most comprehensive information on resource contents.
In addition, while transferring resource contents, data on passengers is available for export/import.
We have yet to utilise or test this new function as yet, looks like a good feature.
Am supposing that ideally it is best utilised with an ibutton or other harware, otherwise it would be like binding a driver or trailer to a specific unit?
Happy for any suggestions on utilisation aspect, including hardware recommendations, from anyone currently using this new module.
Looks like something of good potential use.
FleetPursuit, you're right. It works in a similar way as drivers/trailers. However, passengers cannot be bound to units manually — they can be bound automatically only, with RFID help.
Hello G-Team and "Alek"...
This post is getting old and forgotten, (no new comments in almost 3 months), and we still do not have passenger groups function... How longer will it take? Hope not too long...
Regards,
Hello, jhdeguate! Wait a little more, please. We install passenger groups the next week in Beta.
Thanks a lot Tata... Those are good news...
jhdeguate , passenger groups are available in Beta. Please, try them.
This is wonderful...
Thanks a lot G-Team... Thanks a lot "Tata" for taking care of this...
I am very proud to be one of your distributors...
Best regards!
Hello,
please provide the following info:
Thanks
- 2.Do you provide APIs for Passengers module to create our monitoring mobile app for each passenger?
Yes, see the SDK documentation. Any questions about development you can ask in the special theme.
montasser Teltonika was succefully tested with http://drexia.pl/readers (information from Teltonika support)
I'm not sure that this manufacturer makes Active RFID too.
Hello again, now how can i make a specific user to be able only to see specific passengers on his own account ? do i need to create a new resource for each student and assign each user to the required resource. I think it would be better if you can add to the Access Menu under the user setting an option to select Passengers.
For example if i have 10 students and 10 guardian's accounts, i need only each guardian to see his own student.
Thanks
I wonder whether Active RFID solution includes the describes features on alarm being sent to a parent once a student boards and leaves the bus at certain stops? Have you integrated this into the system?
Maybe custom development using SDK/API
For example if i have 10 students and 10 guardian's accounts, i need only each guardian to see his own student.Thanks
Anyone tried Active RFIDs ? with our experience this doesn't work well.
