Report
Тема: Report
Hi All,
We need a report for our customers that only has to look at ignition state.
So ignition on start trip, ignition off, end trip.
We don't need parking time or any other trip detection.
We got some help by Gurtam support but it is not complete.
We can use report Engine hours for this, or Report Custom Sensors.
Both reports are working great but are missing some fields.
so it would be great for us (specialy for our customers) to add the field STATUS to the report Custom Sensors.
When this is done, the report is just like we need.
Dennis
Report
Re: Report
Hello, Dennis
If either Engine hours or Custom Sensors both suitable for you, then you can use Engine hours to have Status field.
Or maybe there is something specific why you prefer Custom Sensors?
Tatsiana Shmihelskaya
Business Analyst, Gurtam
Report
(27/03/2017 15:13:04 отредактировано Dennis)
Re: Report
Hi Tata!
The report engine hours is not good because it misses correct odometer values.
Wialon Support says:
"Please note it's difference between total mileage Miliage )   and counter's difference , because  to calculate mileage system finds the last value (if it is ) before interval starts , but for counters (initial / last values) it considers only values in interval
If you device  sent mileage value  in every messages such different would be less"
But our devices don't send odometer values so it has to be calucated by Wialon, like in Trips and digital sensor report.
For dutch tax department a trip report has to contain specific fields like in one report (so no extra tabs or something the fields that are required are:
Beginning time ; Initial location ; Initial mileage ; End time ; Final location ; Final mileage ; Mileage ; Driver ; Status ; Notes ; Duration
Report Digital sensors is not good because it only misses fields STATUS so i think it would be the easiest to add only that field, and it should be done, en we but especialy our customers will be happy again!
Report
Re: Report
I found this chat with you and Hugo and our support team.
There was disscussed 2 variants: one with Engine hours and another with Digital sensors (not Custom sensors). And we approved the variant to add initial/final mileage to Engine hours.
Could you please check the current calculation of mileage in both reports and find if there are any differ now? If there is no differ, then maybe it will be OK with our previous arrangement?
Report
(28/03/2017 12:08:04 отредактировано Dennis)
Re: Report
Im sorry it was indeed report Digital Sensors that misses the field Status.
As for now the report Engine Hours still does not give correct odometer values. (see attachment)
As for the report Digital Sensors odometer values is working great but this report is missing the field STATUS (see attachment)
It does not matter for us if you fix report Engine hour or report Digital sensors, most important is that all the needed fields are correct in the report.
  • Report
  • Report
Report
Re: Report
Dennis , seems, you've attached one screenshot twice... So it's still not clear what's the differ..
Report
(28/03/2017 16:00:49 отредактировано Dennis)
Re: Report
Hi tata
i adjusted the screenshots, now they are correct.
Report
Re: Report
Hi, Dennis
i'm following both conversations here and with support team and must admit that both tables are equal for your purpose.
Actually we accepted to add initial and final mileage to the Engine hours tab - so you will enjoy the same as with Digital sensors + Status.
Cannot promise it's gonna be done pretty fast, but if you confirm that this is what you were looking for we will include it in our timeline.
Business Development Manager
Report
Re: Report
Hi poal
Yes that would be great, when we have inital and final mileage in report Engin Hours we are very, very happy!
Report
Re: Report
Dennis пишет:
Inital and final mileage available in report Engine Hours now
