Galileo Sky
Тема: Galileo Sky
Hi
Anyone knows the SMS command to upgrade the GalileoSky Lite ?
Sint
Galileo Sky
Re: Galileo Sky
Hello! Could you tell us please to what firmware version do you need to upgrade and what is your device version GalileoSky v.1.8.5 Lite or v.2.3 Lite?
For example if you need to upgrade to firmware 227 please use the following command Upgrade 227
Galileo Sky
Re: Galileo Sky
Hi Yasintha,
well, here is the answer of GalileoSky Support:
Am 02.12.14, um 11:59 hat Support GalileoSky geschrieben:
But Support will contact you here in Forum
Galileo Sky
Re: Galileo Sky
Thanks
I have both GalileoSky v.1.8.5 Lite  /  v.2.3 Lite
Current software is 199
Sint
Galileo Sky
Re: Galileo Sky
You are welcome. If you will have any questions please feel free to get in touch with our technical support
Galileo Sky
Re: Galileo Sky
Hello!
Сommand  Upgrade 0
Upgrade to the latest stable firmware
Владимир Тихончук
Galileo Sky
Re: Galileo Sky
Hi ,
What would be the duration to upgrade ? and will I loose the existing configuration on the devices ?
Sint
Galileo Sky
Re: Galileo Sky
The duration of update will depend on GSM signal quality and will take some time. You can monitor firmware upgrade by device IMEI on our website. Please follow the link http://f.7gis.ru:8022/
The device configuration will be saved
Galileo Sky
Re: Galileo Sky
Hi ,
Upgrade went well , Im trying to set Ignition1 , once I sent this to the tracker it says "Unrecognized:REQUEST "
Am I sending the correct command ?
Sint
Galileo Sky
Re: Galileo Sky
Hello! It is correct to use Ignition 1 command with a space between Ignition and 1
Galileo Sky
Re: Galileo Sky
Hi
This worked , thank you for your support smile
Sint
Galileo Sky
Re: Galileo Sky
Dear Friends! We are starting to actively interact with our partners on GURTAM forum. We are going to publish all news about GALILEOSKY devices here. Wait for the novelties soon, we will keep you aware!
Максим Ревякин,
8-800-234-51-50
http://7gis.ru/
Galileo Sky
Re: Galileo Sky
We are pleased to inform you that we have significantly reduced the volume of the outgoing traffic. The new data transfer protocol allows sending messages about time, location and status of alarm button of the vehicle in 10 bytes. The fuel sensor data takes only 2 extra bytes. After installing the new 229 firmware, you reduce your GPRS or IRIDIUM expenses by 3 times! If you have any questions please do not hesitate to contact our commercial department in the most convenient for you way.
Tel: +7 342 270 07 99; +7 499 7 044 799
E-mail: sales@7gis.ru
Skype: rokka.julia or galileosky.assistant2
Gurtam Forum: MaxGS
Максим Ревякин,
8-800-234-51-50
http://7gis.ru/
Galileo Sky
Re: Galileo Sky
Dear Partners!
In anticipation of 2016 we would like to resume the results of our collaborative efforts in the past 12 months, to share LLC "RSA "GALILEOSKY" achivements with you, to tell you what hardware advances we made.
The most significant achivements in strategical development in 2015 were the following:
  • The quality management system of LLC "RSA "GALILEOSKY" have been ISO 9001:2008 certified;
  • We took part in globally known exhibitions, such as Cebit (Hannover) and Gitex (Dubai);
  • We underwent the procedure of accreditation as a supplier of ROSNEFT;
  • GALILEOSKY devices were included in a list of recommended equipment for installation in vehicles of GAZPROM;
  • GALILEOSKY trademark was registered in Kazakhstan and Belarus;
  • We have extended the geography of sales and now our equipment is presented in more than 30 countries of the World;
We appreciate each partner and we exercise individual approach to our customers especially considering functional novelties implementation. Building on that we are glad to introduce you our 2015 developments:
1. New autonomous GALILEOSKY BOXFINDER devices launch (December).
Autonomous devices used for control and theft prevention of vehicles and other mobile objects. The devices are able to work without connection to the power-supply source and without battery change for 10 years (when sending messages twice a day).
2. Beta-testing of new devices called GALILEOSKY Base Block Lite.
Brand new compact device is getting ready to the market launch. Soon you will be able to appreciate the functionality and the convinience of the solution (RS485, internal battery, CANbus support etc.), that is expected to be the most affordable from our product range.
3. GALILEOSKY GLONASS/GPS v2.4 market launch.
Modified version of 2.2.8 and 2.3 with the extended power supply range 10-50V.
4. GALILEOSKY programming.
Brand new function that gives our customers opportunity to extend functionality of the devices by developing scripts on their own.
5. Integration with Strih-TahoRUS, Atol Drive 5, VDO DTCO 3283 (Continental) tachografs .
Remote tachograf data transfering to Wialon.
6. Integration with measuring systems "SENS" (NPP SENSOR LLC).
Integration with measuring systems (via RS232) used for monitoring fuel capacity on moving and stationary objects of fuel filling stations.
7. Integration with Eurosens Delta fuel flow meters (JSC "Mechatronica", Belarus).
Connection to GALILEOSKY devices via RS485.
8. GALILEOSKY v2.3, v5.0, v5.1 integration with Trimble course indicators.
Now this function is available on the new devices, with RS232.
9. Implementation of the new data transfer protocol with compression.
With this protocol you can significantly reduce the expences on GPRS and IRIDIUM traffic. The new data transfer protocol allows sending messages about time, location and status of alarm button of the vehicle in 10 bytes.
It is devotely to be hoped that our developments would help you to solve any tasks that faces you and your customers and strengthen our cooperation.
LLC "RSA "GALILEOSKY" team wishes you Happy New Year!
We would like to thank you for a productive cooperation and for your enthusiasm!
We are sure that in the forthcoming year we will reach the new heights together with you!
Максим Ревякин,
8-800-234-51-50
http://7gis.ru/
Galileo Sky
Re: Galileo Sky
Dear All
Could those of you with experience using and deploying the GalileoSky V5.0 and V5.1 share their experience? I just now discovered this manufacturer so I have no info on them apart from the fact that it is the most popular tracker on this platform. How good is the product? How durable? Reliable?
Also, how is their customer service and export experience for clients outside Europe (to Africa for instance)?
Thanks for all your help on this.
Best
Galileo Sky
Re: Galileo Sky
Dear RobertoS
Thank you for your interest in GALILEOSKY products. As the representative of RSA GALILEOSKY LLC I would like to prove our experience as the worldwide vendor of vehicle tracking hardware. Currently we have the dealer network in 30 countries of the World and looking for more.
The hardware that we produce is admired by our customers mostly for reliability and the set of features it provides. That is the reason why we are in the leading positions amongst Wialon users.
For more information please contact us on sales@7gis.ru
Максим Ревякин,
8-800-234-51-50
http://7gis.ru/
Galileo Sky
Re: Galileo Sky
RoberstoS,
we use them (beside also some more lowcost HW). Galileosky HW is extremly professional, very very stable (we never had any broken devices), has all certificates, a very clever programming software (you can configure everything you can imagine) and support is available via skype and email and answers always after a few hours.
If you need help in configuration etc. just ping me.
Wolf.
Galileo Sky
Re: Galileo Sky
Hello Wolf
Thanks for your feedback, I know it comes from real experience. We have a test unit coming our way and it should be up and running in around two weeks.
Best
Galileo Sky
Re: Galileo Sky
Dear colleagues.
We are glad to welcome you to attend the webinar where we will present the brand new GALILEOSKY BASE BLOCK devices. The webinar will take place today on June 8th at 14 PM (GMT +3). You may register for the webinar here http://b17981.vr.mirapolis.ru/mira/Do?i … oaction=Go
Максим Ревякин,
8-800-234-51-50
http://7gis.ru/
Galileo Sky
Re: Galileo Sky
Dear Partners!
We are delighted to welcome you to visit our stand on GITEX, Dubai on 16-20 October! Our company will present a new range of GALILEOSKY tracking devices together with an exclusive technology of independent programming Easy Logic. Visit our booth Z-21 in Zabeel Hall pavilion and we will introduce you to the latest innovations and developments http://gitex16.mapyourshow.com/7_0/floo … Booth=Z-21
Максим Ревякин,
8-800-234-51-50
http://7gis.ru/
Galileo Sky
Re: Galileo Sky
Dear Partners!
We are happy to announce that we are starting the series of online workshops for our international customers that are going to be held throughout the entire 2017. The first webinar will be held on February 9th. This would be the introductory webinar where our commercial and technical specialists will describe you the Galileosky product range, tell you how to pick the right version and what advantages motivate our partners to choose Galileosky devices. For more information about the webinar and for signing up please follow https://events.webinar.ru/1432983/261861
Максим Ревякин,
8-800-234-51-50
http://7gis.ru/
22
Galileo Sky
Re: Galileo Sky
Dear colleagues!
Glad to inform you that we continue the series of online workshops. The next one will be held on March 16th. This time the webinar would be dedicated to the Galileosky Boxfinder asset tracker with 10 years service life (on a single battery). For more information and for signing in please follow https://events.webinar.ru/1432983/311597
Максим Ревякин,
8-800-234-51-50
http://7gis.ru/
23
Galileo Sky
Re: Galileo Sky
Hello everyone!
On April 6th we are going to hold the next webinar. It will be dedicated to Galileosky solutions in the cold chain management. We will discuss the benefits of using of our equipment on refrigerators. For more info please visit https://events.webinar.ru/1432983/358457
Максим Ревякин,
8-800-234-51-50
http://7gis.ru/
24
Galileo Sky
Re: Galileo Sky
Dear partners!
From May 30 to June 1 we are presenting Galileosky solutions at SECUREX 2017 - the largest security trade exhibition in Africa.
The event is taking place at Gallagher Convention Centre in Johannesburg, South Africa. Galileosky stand E20, hall 2 – visit us!
To make an appointment with Galileosky at SECUREX 2017 fill in the form on our website: http://galileosky.com/o-kompanii/novost … frica.html
Максим Ревякин,
8-800-234-51-50
http://7gis.ru/
25
Galileo Sky
Re: Galileo Sky
Hello everyone!
Take part in a free webinar “Eco Driving: proper tracker configuration and report settings”. The event will be held by Galileosky technical support engineer and Gurtam technical specialist.
On the webinar you will find out:
  • How to configure a tracker properly to get full data on driver quality;
  • How to use Wialon Eco Driving module efficiently and benefit from it;
  • How to choose the necessary Eco Driving violation parameters to get a comprehensive driving quality report in Wialon.
Date: Thursday, May 11
Time: 10:00 a.m. (GMT)
Each participant of the webinar will be able to get answers to questions from the technicians in the live chat.
The webinar is free and will take you about one hour. Please, register now to make sure you get a place: https://events.webinar.ru/1432983/420607
Максим Ревякин,
8-800-234-51-50
http://7gis.ru/
