Topic: Galileo Sky
Hi
Anyone knows the SMS command to upgrade the GalileoSky Lite ?
Hi
Hello! Could you tell us please to what firmware version do you need to upgrade and what is your device version GalileoSky v.1.8.5 Lite or v.2.3 Lite?
For example if you need to upgrade to firmware 227 please use the following command Upgrade 227
Hi Yasintha,
well, here is the answer of GalileoSky Support:
Am 02.12.14, um 11:59 hat Support GalileoSky geschrieben:
But Support will contact you here in Forum
Thanks
I have both GalileoSky v.1.8.5 Lite / v.2.3 Lite
Current software is 199
You are welcome. If you will have any questions please feel free to get in touch with our technical support
Hello!
Сommand Upgrade 0
Upgrade to the latest stable firmware
Hi ,
What would be the duration to upgrade ? and will I loose the existing configuration on the devices ?
The duration of update will depend on GSM signal quality and will take some time. You can monitor firmware upgrade by device IMEI on our website. Please follow the link http://f.7gis.ru:8022/
The device configuration will be saved
Hi ,
Upgrade went well , Im trying to set Ignition1 , once I sent this to the tracker it says "Unrecognized:REQUEST "
Am I sending the correct command ?
Hello! It is correct to use Ignition 1 command with a space between Ignition and 1
Dear Friends! We are starting to actively interact with our partners on GURTAM forum. We are going to publish all news about GALILEOSKY devices here. Wait for the novelties soon, we will keep you aware!
We are pleased to inform you that we have significantly reduced the volume of the outgoing traffic. The new data transfer protocol allows sending messages about time, location and status of alarm button of the vehicle in 10 bytes. The fuel sensor data takes only 2 extra bytes. After installing the new 229 firmware, you reduce your GPRS or IRIDIUM expenses by 3 times! If you have any questions please do not hesitate to contact our commercial department in the most convenient for you way.
Tel: +7 342 270 07 99; +7 499 7 044 799
E-mail: sales@7gis.ru
Skype: rokka.julia or galileosky.assistant2
Gurtam Forum: MaxGS
Dear Partners!
In anticipation of 2016 we would like to resume the results of our collaborative efforts in the past 12 months, to share LLC "RSA "GALILEOSKY" achivements with you, to tell you what hardware advances we made.
The most significant achivements in strategical development in 2015 were the following:
We appreciate each partner and we exercise individual approach to our customers especially considering functional novelties implementation. Building on that we are glad to introduce you our 2015 developments:
1. New autonomous GALILEOSKY BOXFINDER devices launch (December).
Autonomous devices used for control and theft prevention of vehicles and other mobile objects. The devices are able to work without connection to the power-supply source and without battery change for 10 years (when sending messages twice a day).
2. Beta-testing of new devices called GALILEOSKY Base Block Lite.
Brand new compact device is getting ready to the market launch. Soon you will be able to appreciate the functionality and the convinience of the solution (RS485, internal battery, CANbus support etc.), that is expected to be the most affordable from our product range.
3. GALILEOSKY GLONASS/GPS v2.4 market launch.
Modified version of 2.2.8 and 2.3 with the extended power supply range 10-50V.
4. GALILEOSKY programming.
Brand new function that gives our customers opportunity to extend functionality of the devices by developing scripts on their own.
5. Integration with Strih-TahoRUS, Atol Drive 5, VDO DTCO 3283 (Continental) tachografs .
Remote tachograf data transfering to Wialon.
6. Integration with measuring systems "SENS" (NPP SENSOR LLC).
Integration with measuring systems (via RS232) used for monitoring fuel capacity on moving and stationary objects of fuel filling stations.
7. Integration with Eurosens Delta fuel flow meters (JSC "Mechatronica", Belarus).
Connection to GALILEOSKY devices via RS485.
8. GALILEOSKY v2.3, v5.0, v5.1 integration with Trimble course indicators.
Now this function is available on the new devices, with RS232.
9. Implementation of the new data transfer protocol with compression.
With this protocol you can significantly reduce the expences on GPRS and IRIDIUM traffic. The new data transfer protocol allows sending messages about time, location and status of alarm button of the vehicle in 10 bytes.
It is devotely to be hoped that our developments would help you to solve any tasks that faces you and your customers and strengthen our cooperation.
LLC "RSA "GALILEOSKY" team wishes you Happy New Year!
We would like to thank you for a productive cooperation and for your enthusiasm!
We are sure that in the forthcoming year we will reach the new heights together with you!
Dear All
Could those of you with experience using and deploying the GalileoSky V5.0 and V5.1 share their experience? I just now discovered this manufacturer so I have no info on them apart from the fact that it is the most popular tracker on this platform. How good is the product? How durable? Reliable?
Also, how is their customer service and export experience for clients outside Europe (to Africa for instance)?
Thanks for all your help on this.
Best
Dear RobertoS
Thank you for your interest in GALILEOSKY products. As the representative of RSA GALILEOSKY LLC I would like to prove our experience as the worldwide vendor of vehicle tracking hardware. Currently we have the dealer network in 30 countries of the World and looking for more.
The hardware that we produce is admired by our customers mostly for reliability and the set of features it provides. That is the reason why we are in the leading positions amongst Wialon users.
For more information please contact us on sales@7gis.ru
RoberstoS,
we use them (beside also some more lowcost HW). Galileosky HW is extremly professional, very very stable (we never had any broken devices), has all certificates, a very clever programming software (you can configure everything you can imagine) and support is available via skype and email and answers always after a few hours.
If you need help in configuration etc. just ping me.
Wolf.
Hello Wolf
Thanks for your feedback, I know it comes from real experience. We have a test unit coming our way and it should be up and running in around two weeks.
Best
Dear colleagues.
We are glad to welcome you to attend the webinar where we will present the brand new GALILEOSKY BASE BLOCK devices. The webinar will take place today on June 8th at 14 PM (GMT +3). You may register for the webinar here http://b17981.vr.mirapolis.ru/mira/Do?i … oaction=Go
Dear Partners!
We are delighted to welcome you to visit our stand on GITEX, Dubai on 16-20 October! Our company will present a new range of GALILEOSKY tracking devices together with an exclusive technology of independent programming Easy Logic. Visit our booth Z-21 in Zabeel Hall pavilion and we will introduce you to the latest innovations and developments http://gitex16.mapyourshow.com/7_0/floo … Booth=Z-21
Dear Partners!
We are happy to announce that we are starting the series of online workshops for our international customers that are going to be held throughout the entire 2017. The first webinar will be held on February 9th. This would be the introductory webinar where our commercial and technical specialists will describe you the Galileosky product range, tell you how to pick the right version and what advantages motivate our partners to choose Galileosky devices. For more information about the webinar and for signing up please follow https://events.webinar.ru/1432983/261861
Dear colleagues!
Glad to inform you that we continue the series of online workshops. The next one will be held on March 16th. This time the webinar would be dedicated to the Galileosky Boxfinder asset tracker with 10 years service life (on a single battery). For more information and for signing in please follow https://events.webinar.ru/1432983/311597
Hello everyone!
On April 6th we are going to hold the next webinar. It will be dedicated to Galileosky solutions in the cold chain management. We will discuss the benefits of using of our equipment on refrigerators. For more info please visit https://events.webinar.ru/1432983/358457
Dear partners!
From May 30 to June 1 we are presenting Galileosky solutions at SECUREX 2017 - the largest security trade exhibition in Africa.
The event is taking place at Gallagher Convention Centre in Johannesburg, South Africa. Galileosky stand E20, hall 2 – visit us!
To make an appointment with Galileosky at SECUREX 2017 fill in the form on our website: http://galileosky.com/o-kompanii/novost … frica.html
Hello everyone!
Take part in a free webinar “Eco Driving: proper tracker configuration and report settings”. The event will be held by Galileosky technical support engineer and Gurtam technical specialist.
On the webinar you will find out:
Date: Thursday, May 11
Time: 10:00 a.m. (GMT)
Each participant of the webinar will be able to get answers to questions from the technicians in the live chat.
The webinar is free and will take you about one hour. Please, register now to make sure you get a place: https://events.webinar.ru/1432983/420607
Hello stortiloris!
Please write us at sales@7gis.ru.
We would be pleased to advise you on how to purchase Galileosky devices in Europe.
Dear partners!
Take part in a free webinar, devoted to presentation of a new range of GPS tracking devices Galileosky 7. On the webinar you will find out all the necessary information about the latest telematics solution of the Russian vendor:
Please follow the link to book your seat https://events.webinar.ru/1432983/464815
Hope to see you also in Minsk in July to get some more infos
Wolf.
Dear colleagues!
Another webinar session is planned to be held on 6th of July. The topic we are going to discuss is one of the most interesting and at the same time challenging in vehicle telematics. This online workshop will be dedicated to the connection of Galileosky devices to the CAN-bus.
Don't miss the chance to attend this webinar. Please, register now to make sure you get a place: https://events.webinar.ru/1432983/487487
