151
Teltonika FM1100
Re: Teltonika FM1100
Hi Harm,
thats how we do Odometer testing :-) We have a trip on autobahn which is exact 100km with really very low number of curves.
works perfect to check which odometer is the right one...
(on my Skoda Octavia with standard tyres its less then 1% wrong)
Wolf.
152
Teltonika FM1100
Hi Wolf,
Test with my VW Passat 2.0 TDi :
  • From June 9 2010 till March 27 2011
    Used tyres: Summer and winter tyres
    Driven distance 28327 Kilometers
    At end of test Odometer in car : 127057
    At end of test in Wialon             : 126893
    Difference: 164 km this is : 0,578952942 %  !!
I used original tyres, advised tyre pressure, etc ...all according ""the book""
Note : the PDF is written in Dutch language
Attachment icon GPS kilometers versus Kilometer teller.pdf 236.51 kb, 759 downloads since 2016-01-25
153
Teltonika FM1100
Dear All
I'm having some issues with the FM1120. We have been testing 2 devices and both exhibit the same issue. Regularly (a couple of times a day) the device will stop reporting the position of the vehicle while it is moving. This can last up to 40 minutes. At some point it sends all the position reports that were not received during that period. GSM coverage is not a problem as both devices remain in the city and I know there is no issue on that side. Furthermore, we've not had similar problems with other brands of trackers.
FW version is: 1.1.0.12
Has anyone had the same problem? Were you able to fix it?
Thanks
154
Teltonika FM1100
I have teltonika FM100 device but i forgot the password i set on the device, now i have to change APN but i can not access device as it requires password, how can i solve this?
155
Teltonika FM1100
Only Teltonika can provide you with a reset key.
There is no other way.
Wolf.
156
Teltonika FM1100
Hello
Please can anyone help me to reset code of teltonika Fm100 .
157
Teltonika FM1100
Anyone has a protocol description for this device?
Thanks in advance
158
Teltonika FM1100
aahero communication protocol is commercial secret of manufacturers.
Please describe more detailed what information do you need. We'll try to help you.
Thanks.
Viktor Yarovenko
Business Analyst
Wialon
159
Teltonika FM1100
Thanks.
I just need parameter description ,which param is what
„Engine coolant temperature“  5
„Engine RPM“  6
„Throttle position“ 7
„Vehicle speed“ 8
„Fuel level“  9
„Number of DTC“  90
„Calculated engine load value“  91?
160
Teltonika FM1100
I/O  parameters of Teltonika number "N"  are transmited like Param "N" in Wialon
Some numbers of parameters are renamed in Wialon.
Unfortunately Teltonika sometimes changes numbers of I/O that's why names in Wialon can indicate wrong parameters. We'll try to fix it later.
Please see description of your parameters:
„Engine coolant temperature“  = Param5 in Wialon
„Engine RPM“  6   = Param6 in Wialon
„Throttle position“ 7 = Param7 in Wialon
„Vehicle speed“ 8 = Param8 in Wialon
„Fuel level“  9 =   (ADC1 in Wialon) -- Because I/O №9 was reserveв for ADC1 for other Teltonika devices .
„Number of DTC“  Param 90 in Wialon
„Calculated engine load value“  91 = Param91 in Wialon
Viktor Yarovenko
Business Analyst
Wialon
161
Teltonika FM1100
Fuel level is not shown on server side as 9 or adc1 it is simply missing.But it is recognised in CANbus scan and LVCAN200 can send it so it is definitely missing on server side .
Please check
162
Teltonika FM1100
aahero please write an email to hw@gurtam.com
Please clarify ID of your unit, mobile phone number of SIM card, and attach your current Teltonika configuration file and  your configurator.
Thanks.
Viktor Yarovenko
Business Analyst
Wialon
163
Teltonika FM1100
just trying the same :-) LV200 with fuel level.
If the device is active, i will send you the data.
Wolf.
164
Teltonika FM1100
Wolf.
LVCAN200 is working fine I am just trying to get the same with FM1000
165
Teltonika FM1100
Hello guys.
We just got a client who already has some teltonika fm1100 devices for some time. When trying to configure them we get a "Enter pasword" request from the configurator. He has no ideea about the devices beeing password protected and the local company from where he bought them don't remember smile
Any ideea if there is a solution for resetting the password? Thanks
166
Teltonika FM1100
florin1 Ask teltonika who was a dealer (by IMEI) and contact this company.
Viktor Yarovenko
Business Analyst
Wialon
167
Teltonika FM1100
Please help me.
Any body know the Applicable Type of Vehicles /TELTONIKA FM1000/
It's my life
168
Teltonika FM1100
(edited by b.chuka 31/07/2016 17:27:26)
Hello experts.
I don't know to install  teltonika fm1000 how many types of vehicles. Please tell me, Anybody know this. I need the list of Applicable Type of Vehicles /with CAN data, without CAN data/.
It's my life
169
Teltonika FM1100
Hi Everyone
Does anyone know what the syntax is for sending an i-button serial to an FM11XX unit?
Hope it can be done. Would be a pain to have to get hold of the vehicle every time.
Would appreciate anyone’s input.
Thanks,
170
Teltonika FM1100
Dear Friend,
       I try to add Teltonika FM1100 to my account. Firstly I configured FM1100 with server IP: 193.193.165.165 and port: 20412. Then I add new unit in my account by navigate to unit tab in account and click New, a popup window . I enter name , device type: Teltonika FM1100 and Unique ID: IMEI of device. Then I click Ok. No connection established between server and FM1100 device.
I try Gurtam GPS Device Unique ID Checker, but it also did not appear. I get configuration of GPRS form my GSM provider. Can any one help me. Firmware version of FM1100:  01.17.02.Rev:4
Thanks
171
Teltonika FM1100
ahmed.ibrahem  Can you please write to hw@gurtam.com. Describe your problem, and, please, add  device configuration file and device IMEI to letter. Thank you.
172
Teltonika FM1100
Is that possible to setup SMS command to cut of engine and then enable engine back in Teltonika FM1100 if yes please explain to me in details how?
Thanks in advance
173
Teltonika FM1100
username password setdigout 10 = set dout1 to 1
username password setdigout 00 = set dout1 to 0 (dout 2 also to 0)
Regards WOlf.
p.s. reading the manual always helps! If you start working with that HW you need to read it for sure
searching for "teltonika fm1100 manual pdf" in google brings on the first 25 URL manuals for the above device
174
Teltonika FM1100
To people that are successfully using Teltonika devices, may I ask what is the failure rate of FM1100 based on your personal experience ?
To people that had problems, what component failed: firmware (bug), cables and socket, antenna or whole device ?
175
Teltonika FM1100
Does any one can help me to connect FM1100 with 08.03.02
I have no configurator that connects it?
