Здравствуйте!
вот, что гласит мануал:
Setconnection – change connection configuration
SMS message is used to permanently change FM device  configuration settings: APN, APN username, APN password, protocol, IP1, PORT1, IP2, and PORT2 (parameter description: 3.1.6).
SMS format: pass setconnection apn,apnlogin,apnpassword,Protocol,IP1,Port1,IP2,Port2
Example: pass setconnection apn,apnlogin,apnpass,TCP,111.111.111.111,1111,222.222.222.222,2222
Response example: set connection data ok
If one of the parameters should be preserved, then the specific location for the parameter should be filled with *old*. For example, ip1 and port1 should be preserved (old value should remain):
Example: pass setconnection apn,apnlogin,apnpass,TCP,*old*,*old*,222.222.222.222,2222
If the message is not ending with port2, then those parameters, which are not mentioned in the message should not be changed. For example ip2 and port2 were not in the message:
If configuration failed to set when FM device sends response: Set connection data incorrect
отправьте команду " setconnection internet,,,TCP,123.45.67.890,12345"
обратите внимание, перед командой необходимо оставить один пробел
						Pavel Čumakov
Ruptela
