Re: WiaTag
ysv
You can query photo by Query snapshot command. If you need 10 photos, the command should be executed 10 times.
JohnG
Firstly, activate "Remote control" option in WiaTag settings.
ysv
JohnG
Kalaschnikow
I can't log in with the application to my hosting account so can't test it. Initial thoughts are that we need to be able to customize the fields that are displayed and it should be triggered by a status from within Wiatag. Having to work between two applications is not a good situation.
I may have solved the problem initially by creating a special status with the sales values and the user selects the value. If this status can be triggered by the developers from another status through the setting of a parameter it would be ideal.
Hi Kopa.
It is activated on the device but I still get the error
About logging in please check my answer on another thread (about WERA). And about the ability to send some events on status change: we can do it if Gurtam opens Intents. Before it, it is not possible.
Another way to do it is to integrate it with Wiatrack Pro. But Wiatrack Pro is not free.
Hi Kopa.
Please send us WiaTag's logs to the development@gurtam.com
Kopa how do I get the logs?
Would be good if the app had a function where we could just send the logs to development :-)
JohnG WiaTag has this option (Administrative Settings -> Debug mode -> Send logs (docs page 21)).
logs sent Kopa
Great to have the manual as well
John
We are doing a POC of Wiatag for sales force tracking and need to be able to send out a route for the sales person to become a set of statuses in Wiatag. We can create the visit schedule in Wialon as a route but because the stores are close together we are worried that the checkpoint will not trigger correctly. The option is to have the checkpoints as statuses in Wiatag and the sales person selects the checkpoint he is visiting.
We need to have up to 30 statuses for this scenario. I can do it by creating multiple status groups but this is not easy to manage.
Is this possible?
John
When we are running on a schedule and we reach the end time of the schedule how does Wiatag show that it is inactive? Does the service state change to show the off time of the schedule is triggered?
john
Will Wiatag be released on Github so we can customize the application?
logs sent Kopa
John
On this issue, I've sent you a reply as a private message.
Is this possible?
John
Maybe you'll like our new application Wialon Logistics, which will be released in March, 2016. I think, it covers your requirements. Just follow the news in our blog.
john
Wiatag status is shown in the notifications bar. When Wiatag works, there is a special icon there; when it stops, the icon disappears.
If you see no such icon, enable it in Settings => Administrative settings => Notifications => Show app status.
No, we don't plan it.
Fixed this issue. The command has to go out as a virtual command. Once I did that I can get an image for both camera's on my S6 Edge.
Great feature and thanks to the Development team for this feature.
Hi,
you can integrate the command, send location ?. And when you open this type of notification that ask hbrirlo with an application. For example: waze, google maps or google earth.
To have an assist of driving to get to the requested location.
soporteCA
Thank you for your proposal.
We'll consider your remark when developing further versions.
para crear una cuenta de wiatag es de pago o gratis?
El uso de WiaTag es gratis para los usuarios de Wialon Hosting. Si no tiene cuenta de Wialon todavía póngase en contacto con nuestro departamento de ventas: sales@gurtam.com
Started to use wiatag .
Great application. Perfect tracking and the Current consumption is amazing good.
The only thing I miss is simple remote setting of wiatag from Wialon.
koby
Hi ,
I see a new option " NFC Reader" in Wiatag , what does this do ?
Can we read NFC cards / Tags using a smartphone and send the tag ID to Wialon platform ?
In testing the NFC side we have been able to get the QR function to work but have had no success to get the application to read NFC tags. The tags can be read by other NFC applications on the same smartphone.
ysv, JohnG,
If you activate NFC option in the WiaTag settings, you can send tag's value by two ways:
- go to the main screen in the WiaTag and place a tag to the device
- go to the home screen at your device and place a tag to the device and then check WiaTag at system dialog which contains NFC compatible applications list (If you have chosen default NFC application, you should reset this at device settings)
Upon reading a tag, a message containing 'nfc' parameter is sent to the server.
Thanks for the explanation ,
both NFC tag read and QR code worked for me on Galaxy S6.
ysv, JohnG,
Thanks Kopa
Is there any way to
1. Show what is being read from the QR capture and NFC capture on the screen for the user, and
2. capture the text information on the tag so the user can see it. We encode different items in the test like the item description, inspection information
etc and would be great that when the user uses Wiatag to scan they see this. The ID is automatically sent on the scan to the server.
Also is it possible to integrate Wiatag with an application like AutomateIT or NFC Tools Tasks so that we can trigger an action on the read?
Thanks Kopa
Is there any way to
We will explore the possibility of implementing such functional.
