WiaTag
(edited by kopa 16/02/2016 09:15:59)
Topic: WiaTag
WiaTag is a new mobile GPS tracker designed specially to work with Wialon system.
WiaTag
+ beta testing
If you want to become a tester,follow the link and become a tester. Then a link for downloading the app will appear. Install the app and enjoy.
Your feedback, constructive criticism, and suggestions are highly welcome!
Mobile Development
WiaTag
Re: WiaTag
do we post feedback into this topic?
Phoenix Solusi
Mobile Visible Secure
WiaTag
Re: WiaTag
JohnG Yes. You can also send your feedback to development@gurtam.com or leave it at the Google Play. wink
Mobile Development
WiaTag
Re: WiaTag
Ok Great I will start testing today
Phoenix Solusi
WiaTag
Re: WiaTag
Kopa should we also post suggestions and issues here in the forum so other testers can comment or give input ?
Phoenix Solusi
WiaTag
Re: WiaTag
This application has has a lot of potential and should be a great tool for users to use with Wialon.  Status creation is very simple and this on its own is a great benefit.
Phoenix Solusi
WiaTag
Re: WiaTag
JohnG, thank you for your feedback.
Surely, you can post suggestions right here, in this topic, so that everybody could read and comment.
Mobile Development
WiaTag
(edited by JohnG 22/12/2015 20:26:25)
Re: WiaTag
After initial testing I have the following items
1. Is this product going to replace GPS tag or is it an additional product?
2. I can't set the schedule for the operating time for the application.
3. When a picture is uploaded is it possible to to have some sort of confirmation it has been sent and if it is a large picture can we have a progress bar to show status of the upload.
4. Can we add to the action list? I would like to have the ability to have a hyperlink that would allow for connecting to other applications.
5. How do we remotely connect to the Wia Tag?
6. Is it possible to have the ability to enter text messages as an action item
7. Have the ability to read NFC tags or bar-codes and send that information to Wialon.
Is there a user guide for the product?
Phoenix Solusi
WiaTag
Re: WiaTag
JohnG
1. It is an additional product.
2. We'll check it
3. Progress bar isn't possible here but, with any result, you'll get a toast message ("Photo sent" on success or some kind of error).
4. It's an interesting proposal. We'll consider it for further versions.
5. Via commands in Wialon Hosting
6. WiaTag is only a tracker and texting is not a part of it.
7. We'll consider it for further versions.
User guide in progress.
Mobile Development
WiaTag
Re: WiaTag
Thanks for the reply Kopa,
We are working on some solution sets at the moment and what i want to do is to change the statue group that is in use from Wialon how do I do that? The use case is that i have a technician that starts using one group of statuses but based on sending a status from that group i want to switch him to another status group.
Can I create new status groups remotely? so i have a supervisor that needs to create a checklist to be completed by the field services person. The checklist depends on the findings from the first set of statuses, is that possible as well?
Regards
John
Phoenix Solusi
WiaTag
Re: WiaTag
For the sent message for Item 3 I do not always get the sent message. In my testing even though it said it had sent the photo it did not always show up in Wialon. Checking the application the blackbox was shown as empty. Today I found that if the battery is low (30%) the messages did not show up in the blackbox, that is it was empty and i could not change the status. However when i connected to power 3 messages appeared in the blackbox and i could send a status change. Is this normal? I am testing on a Samsung S6 edge.
Also in the final version will we be able to edit the "Contact Us" details to not default to support@gurtam.com?
Phoenix Solusi
WiaTag
Re: WiaTag
Yes, it's possible to create remote status remotely, however, sets of statuses can't be interconnected.
We'll investigate the issue about WiaTag work with low battery. Thank you for your concern.
It's probable that the "Contact Us" details will be editable in future, under White Label.
Mobile Development
WiaTag
Re: WiaTag
Thanks Kopa
Do we have a user manual yet?
I want to test the remote connectivity
Regards
John
Phoenix Solusi
WiaTag
Re: WiaTag
Hi Kopa
Where I can find the user manual ?
Best Regards
Samuel
WiaTag
Re: WiaTag
The User Guide is in progress and will be ready in a couple of weeks.
Katerina Alexandrova
Product Manager (Mobile)
WiaTag
(edited by n.sehictz 01/02/2016 13:43:20)
Re: WiaTag
Greetings,
I cannot install Wiatag for some reason - this is what comes up: http://i.imgur.com/cLs7YLe.png
Tried both via PlayStore and Chrome browser, any clues? (I am registered as a tester)
Thanks
EDIT: Fixed it! For anyone who has same problem - after registering with your smartphone, log in from desktop using the same googleplay account and then click Install from desktop, the download will begin on your device.
WiaTag
(edited by JohnG 09/02/2016 10:43:11)
Re: WiaTag
any update on the manual?
Also when will the producti0on version be available ?
Phoenix Solusi
WiaTag
Re: WiaTag
Is it possible to have entry fields associated with the status? We have requests from companies that want to use it for sales person tracking and they want the salesperson to enter the sales value when they select the status "sale is made". It would be good if we had the ability to have a number of these text entry fields and we could link to which status they would be triggered from. So when the trigger status is selected the field would pop up for the entry.
They are also raising the ability to capture NFC tag or barcode information this is a feature that I requested before so can this be looked at in one of the sooner future updates :-)
Phoenix Solusi
Re: WiaTag
I think this utility can help your customer.
WiaTag
Re: WiaTag
JohnG, the manual is almost ready. It will be available really soon (this very week) I hope.
WiaTag
Re: WiaTag
We looked at Wiatrack and its Pro version before and it is not suitable
Phoenix Solusi
22
WiaTag
Re: WiaTag
Great news Alek
Phoenix Solusi
Re: WiaTag
JohnG, check the link I sent previously. The utiliy I mean is NOT Wiatrack or Wiatrack Pro.
24
WiaTag
Re: WiaTag
Hi Kopa ,
Can we have a command to take 10  snapshots with 5 seconds delay in between each snapshot ?
I'd like to rigger something like that if Device enters or leaves a Geofence.
Sint
25
WiaTag
Re: WiaTag
The snapshot may be able to be done with the Get Image command triggered by a notification that fires on the entry or exit from a Geofence. If that can be modified so that we can specify a number of images and the frequency (in seconds) between them it would be great. eg Get Image 5,2 so the device takes 5 images separated by 2 seconds. So in your case ysv  it would be Get Image 10,5
When I send the command to WiaTag running on a Samsung S6 I get an error.
16.02.2016 17:27:54: Command 'Get Image' sent to unit 'S6 Edge Test'.
16.02.2016 17:27:56: Error executing command 'Get Image' for unit 'S6 Edge Test'.
Phoenix Solusi
