Topic: Minimum Stop Time
Hello!
I would like to request a new feature that would be included possibly in the trip detector.
I would like to be able to set up a "minimum stop time". Right now we have the ability to do this with parkings, but currently anything under that time is considered a stop.
This has caused some confusion with my customers when they see stops that last zero seconds in the reports. Now I am aware we can set the duration in the report properties, but if you include the stops on the map you will see everything under the parking time.
If we could set the minimum park time to one minute for example it would help to eliminate stops that occur because of reporting rates. For example, if we have a device that reports every minute and a zero speed comes in between two reports with speed, the system will mark it as a stop but it will only be listed as zero seconds. It would be nice to cut these out.
Thank you for your consideration.
