Topic: Meitrack VT300
Hi,
I was trying to reconfigure the VT300/310 meitrack hardware and succeeded to a good extend bodies not complete the following.
1. As per image I cannot figure out the ACC wire as they talk about two wires (green and blue) to connect.
2. In sensors, the engine ignition sensor parameters are not found (eg. In1, In2 etc)
3. How to set the angle to 15 degree by sending SMS commands
4. To save data, how can i set the sleep mode when there is no movement or sign is in off position
Regards,
Abraham
