getting every nested rows from an executed report in a single API call
Topic: getting every nested rows from an executed report in a single API call
Hello,
We would like to get every nested rows from an executed report in a single API call. As you can see at the attached picture.
I need to import every "subrows" in one request.
1 . report/cleanup_result
2. report/exec_report
3. report_select_result_rows ({"tableIndex":0,"config":{"type":"range","data":{"from":0,"to":<row.count from exec report result>,"level":0}}})
4. And here I want to get all "subrows" for the "main" rows from above response. There are many "main" rows, not just one. (At my picture are 2 blue lines)
Also downloading each "subrows" in different requests is very slow..
With an ajax call we can get "subrows" in different requests (when I click on plus):
report/select_result_rows - params:{"tableIndex":0,"config":{"type":"row","data":{"rows":["2"],"level":0}}}
I need the same result/response as the above request produces, but for many "main" rows, not just for one from SDK.
Any idea how can we manage this?
Thx,
Attila
  • getting every nested rows from an executed report in a single API call
Eflotta Vehicle Tracking Ltd, Hungary
www.eflotta.com
Re: getting every nested rows from an executed report in a single API call
Hello
You can use this params for report/select_result_rows request to get rows range with nested subrows
params: {
    'tableIndex': 0,
    'config': {
        'type': 'range',
        'data': {
            'from': 0,
            'to': 0xFFFF,
            'level': 1
Many thanks, it worked well!
www.eflotta.com
