Topic: Rough Fuel Chart
Hello !
I have been testing the wialon fuel reports using RS232 FLS. and found out that mainly when the vehicle is in motion the fuel chart appears really rough with full of ups and downs, which may lead to false refilling or drains. the only solution I found to avoid such false alert it setting a tolerance value, but doing this may cause ignoring real fillings and thefts in the tolerable range.
Dont you think it is better to create some smoothing and peak ignoring algorithm considering the property of fuel and a vehicle in motion, so as to provide clients with smooth fuel graph and reliable theft and drain info the smallest possible level.
