SMS Top-Up Notification
Тема: SMS Top-Up Notification
Hi there
Are you able to develop a feature so that once one loads an sms bundle for a client, we can create a notification to be sent to the client notifying them when their bundle is nearly done?
Example:
Load 200 sms's. Client gets notified each time 50 sms's are used?
Thanks in advance!
Re: SMS Top-Up Notification
Hello,
There is no such option currently - to achieve the needfull you should - perform the login and get the statistics, after that your own separate application should compare previous data on the number of available messages with current one - if the level drops for a desired quantity - you send an alert. Also you can propose such a functionality here - http://forum.gurtam.com/viewforum.php?id=53
