Topic: Accident Impact sensor
Hello Partners,
I would like to start a new project .
Below is the information
The eCall system is triggered by sensors in the vehicle like those which cause protective airbags to explode in a crash .We install a black box (in-Tele-box GPS Tracker ) in your car which can sense any strong impact on the car. If the box registers a large bump, an alarm goes off in our 24 7 live Control Service Centre with alarms dispatch .
Once we receive an alert immediately we will locate the car and if the car is stationary, our trained team will try to call you on your mobile phone, We will check if you are OK and try to help you get going again. If we can see that your car is moving (using our live mapping system) we will assume you are unharmed and do not require immediate assistance.
In case we cannot reach you on your phone, using our inbuilt 2 way voice communication system built in the black-box we will call the black-box automatically answer the call assess the situation and if we need to send the rescue team a dispatch is done immediately .
I have 2 ruptela devices i got last night ECO4 and Tc04 how can i achieve this and is there an addational impact sensor i can use on the devices say i use some of the outputs .
Regards
Steve
