WondeProud VT10
Topic: WondeProud VT10
Hello Guys,
Anyone has idea on how to Configure or SMS commands i need to Send to configure VT10 vehicle Tracker .
Also if someone has Wondeproud Application can share with me i would be very gratefull ,
I am new member and very excited to use Gurtam / Wialon platform
I can see this information
Device type:    Wonde Proud VT-10
Unique ID:    Custom programmed value
what does custom programmed value means
Regards
Steve
WondeProud VT10
Re: WondeProud VT10
Dear Steve,
Custom programmed value unique ID means that you can manually change it for your device. Look through the manual or ask tracker manufacturer, how to do it. Aslo you can look for help from other VT10 users on our forum.
For Wialon Hosting: you should firstly check, if your chosen IMEI is free for this device type.
@ Oleg Zharkovsky
WondeProud VT10
Re: WondeProud VT10
Thanks for your Reply
I have managed to get application to configure the Device and did set all settings fine and sent to the device,
But i still cannot get the Device to work on platform anyone has experience on this as i can see there over 100 Same devices being used on Wialon Hosting .
See Attached
Regards
Steve
  • WondeProud VT10
WondeProud VT10
Re: WondeProud VT10
You can also try our platform and we provide you with cost-effective service and products. For more information, you can contact Jason at jason@concox.cn or Jennifer at support10@concox.cn. Thank you for your time.
Concox is a professional GPS Tracker manufacturer in China providing GPS vehicle tracking devices and mobile phone trackers all over the world in excellent quality at factory price www.iconcox.com
WondeProud VT10
Re: WondeProud VT10
hello good day
I have the same situation,
I have not been able to configure these gps, I appreciate your help with the ideal software
Best regards
See Attached
Regards
Steve
Lps Trackers
WondeProud VT10
Re: WondeProud VT10
lpscolombia wrote:
hello good day
Best regards
Hello,
Please, see the attached manual
https://drive.google.com/file/d/12ZI_ja … sp=sharing
All the commands are sent through the program "Terminal" or "HyperTerminal"
WondeProud VT10
Re: WondeProud VT10
Thanks, you know the speed that I should use for this configuration, I have tried several times but, there is no answer from the gps
taiv wrote:
lpscolombia wrote:
hello good day
Best regards
Hello,
Lps Trackers
WondeProud VT10
Re: WondeProud VT10
As I remember the speed should be 57600
https://www.screencast.com/t/QLLmVzPT
https://www.screencast.com/t/Qsi7EVIRk
taiv wrote:
lpscolombia wrote:
hello good day
Best regards
Hello,
