Тема: adapter (controller) for resistive type floating fuel level sensor
GuardMagic DAFS - Adapter (controller) for resistive type floating fuel level sensor with analog output and EIA-485 communication interface.
GuardMagic DAFS is intended for connection car, light vehicle regular floating fuel level sensor to GPS-GSM/GPRS module.
GuardMagic DAFS intended to read the analog signal from the vehicle regular resistive type floating fuel level sensor and converts it into:
- digital form: EIA-485 communication interface;
- stable noise and pulse free analog voltage output 0-8,5 V range.
GuardMagic DAFS could be used to provide fuel monitoring function on passenger cars, “JEEPs”, VANs,“pick-up” or light trucks (Light Commercial Vehicles) on which the use of DLLS fuel level sensors is not reasonable due to technical, or economic reasons.
Advantages:
- Wide voltage input range
- Valuation of the input signal
- External filter
- Programming the operating parameters
- Dual output: analog and digital
- High resolution.
Application:
Car, “Jeep”, VAN, Mini Bus, Light Trucks, “Pick-Up”.
GuardMagic DAFS allow by very economical way embed fuel monitoring function for cars, VANs, LCV in vehicle monitoring system.
Download leaflet: http://guardmagic.com/01-engl/2e-produc … eaflet.pdf
