Unit Realtime API
(edited by chanden 14/07/2023 12:53:04)
Topic: Unit Realtime API
Dear Wialon,
Good day to you!
Could you please advise me how to get Unit with realtime data (Location , speed, gelocator) as Websocket ?.
Thanks.
Unit Realtime API
Re: Unit Realtime API
chanden hello, in order to start using Wialon API you need to generate token with authorization and then login with this token to generate session ID (sid). This sid should be used in your further requests. In order to get information for all available units, you can use search_items request with flags value 1025
Sample of the request execution -- https://sdk.wialon.com/wiki/en/sidebar/ … y_property
In case you need only GPS data, you can try to use retranslation. Configure retranslator in Wialon. The data will be sent to your server according to the selected protocol.
The list of the integrated protocol you can find here -- https://gurtam.com/en/gps-hardware/soft
Anton Zinovyev
Technical Care Engineer (L2)
Wialon
Unit Realtime API
Dear Wialon,
I would like to ask you  some questions as below :
1. Is it possible request unit with geocode in per request :
    EX: https://hst-api.wialon.com/wialon/ajax.html?svc=core/search_items&params={"spec": {"itemsType": "avl_unit","propName":"sys_name","propValueMask": "*","sortType":"sys_name","or_logic":"0"},"force": 1,"flags":13644935,"from": 0,"to": 0}&sid=10ec4aa7b154a9fc0ac124fbf4d7537f
2. Could you advise me how to get all vehicle status as below:
  - Online
  - Offline
  - Stationary
  - Stationary with ignition on
  - Moving
  - LBS detected
  - No actual state
  - No Message
3. How to get Sensors status as below :
   - Ignition
   - Amount of fuel
Please kindly to check my attached file
  • Unit Realtime API
  • Unit Realtime API
  • Unit Realtime API
Unit Realtime API
chanden good day.
1. You can only get a coordinates with last location of the units. You need to add flags value of 1024. Then you can use coordinates into [code=https://sdk.wialon.com/wiki/en/sidebar/remoteapi/apiref/requests/address]gis_geocode[/code] request as pet the [code=https://sdk.wialon.com/wiki/en/sidebar/remoteapi/codesamples/address_coords]example[/code].
2. Most of the data can be received via search_items or search_item requests.
Online/Offline state regulates with 2097152 flags
Stationary/Moving state can be determine as per the speed value in the last message. Flag 1024
LBS detected, No actual state, No Message -- presumably, these states you can check requesting lat message with corresponding [code=https://sdk.wialon.com/wiki/en/sidebar/remoteapi/apiref/messages/load_last]request[/code].
Possible parameters and description you can find [code=https://sdk.wialon.com/wiki/en/sidebar/remoteapi/apiref/format/messages#message_with_data]here[/code].
3. In order to get sensors values, you can use two different options:
- Via [code=https://sdk.wialon.com/wiki/en/sidebar/remoteapi/apiref/unit/calc_last_message]calc_last_message[/code] request. The reply shows sensors values from the last message by the sensors ID. In order to determine sensor ID you can use search_items request with flags value 4096
- you can use [code=https://sdk.wialon.com/wiki/en/sidebar/remoteapi/apiref/events/events]events[/code] to control sensors states changes. This option describe in the [code=https://www.youtube.com/live/nUtNS5Al5wo?feature=share]webinar[/code].
Let me know if you have any additional questions.
Anton Zinovyev
Wialon
Unit Realtime API
(edited by chanden 02/08/2023 12:34:28)
Dear zant,
Good day to you,
My problem not solve with stationary with ignition on .
Could you give an example how to count stationary and stationary with ignition on.
Pleas kindly check my attached file .
Thanks!
  • Unit Realtime API
  • Unit Realtime API
Unit Realtime API
chanden hello, in order to determine such status you can control two values - ignition sensor value and speed value. Thus if the ignition is ON, but speed value is below minimum moving speed specified in the trip detector - this is stationary with Ignition ON.
Anton Zinovyev
Wialon
Unit Realtime API
Dear zant,
Thanks for your super support .
One more thing ,
Is it possible to executing several commands API at once as below:
1.Parking
2.Count km
3. Km/H
4.Fuel
5.Route on map
Please kindly help to check my attached file
  • Unit Realtime API
Unit Realtime API
chanden hello, in this case you can try to use events. You need to add units into the session with required parameters. Then you can check updates of the events.
Here you can watch events video tutorial -- https://www.youtube.com/watch?v=nUtNS5Al5wo
Anton Zinovyev
Wialon
Unit Realtime API
Thank for the reply,
i do execute with this url : https://hst-api.wialon.com/wialon/ajax.html?svc=report/exec_report&params={"reportResourceId":26768527,"reportTemplateId":1,"reportObjectId":1,"reportObjectSecId":0,"interval":{"from":1690879883,"to":1691743883,"flags":0}}&sid=105e727acae1c014885dc47d9b18cbdf
getting error in API error : 7
One more thing,
How to get  reportResourceId, reportObjectId , reportObjectSecId
Unit Realtime API
chanden hello, the reportObjectId indicated incorrect. It should be internal (system) ID of the element.
In order to get it you need to execute search_items request. You can use this request to find internal ID of any item created in the system. For example, in order to find units IDs you need to set itemsType parameter value to avl_unit and set flags value 1. To get resource ID and report template ID in one execution, itemsType should be avl_resource and flags value 8193.
reportObjectSecId -- should be used if the report template created for resource content, like geofences or drivers.
Also, please, check this article regarding first steps in Wialon API -- https://wialon-help.link/1b0dd04d
It contains all initial information including search_items request description.
Anton Zinovyev
Wialon
