Topic: New Filter Option: Drivers
Hello,
Problem:
One client has requested this new filter to work in the same way as Geofences and Units.
There are drivers that have diferent working hours, they work less than the others so when they generate a report by group of units, every driver remaings appearing in trip and parkings reports.
Solution:
To avoid appearing trips and parkings done by these drivers, the tables could have an option to select if you want to appear only records with or without these drivers, in the same way that there is the option to filter units and geofences.
Technical Support, Rastreasul
fernando@rastreasul.com.br
