Тема: Documentation appState.json Wialon Logistics
Hello, let me tell you that I have the need to use the planning, distribution and warehouse configurations of the users in Logistics, I discovered when reviewing the debugger that the logistics saves its configuration in the following file
svc=file/read params ={"itemId":14622129,"storageType":2,"path":"\/wialon\/apps\/ordermanagement\/appState.json","contentType":0}
from the above the following answer is obtained :
{"content":"{\"o\":{\"res\":14622130,\"e\":\"14622130__46079\",\"eI\":-1,\"eF\":\"14622130__264947942625627\",\"r\":100,\"trt\":3600,\"ut\":600,\"w\":0,\"v\":0,\"of\":131,\"st\":\"08:00\",\"et\":\"17:00\",\"mm\":50000,\"md\":15000,\"moc\":0,\"mi\":3000,\"si\":0,\"crf\":256,\"acch\":false,\"nt\":1200,\"ntf\":16,\"cr\":0,\"af\":[]},\"tc\":1,\"i\":{\"f\":\"dd\/MM\/yyyy HH:mm\",\"s\":\",\"},\"mu\":{\"c\":\"\",\"ec\":\"\"},\"m\":{\"p\":1},\"gis\":{\"p\":1,\"s\":15,\"cityJams\":1,\"countryJams\":1,\"mainprovider\":1,\"sCountry\":\"\",\"sCity\":\"\",\"zoom\":0,\"modetravel\":\"driving\",\"traffic\":1,\"group\":1},\"ap\":[\"compl\",\"next\"],\"aps\":false,\"ep\":false,\"__v\":\"3.10.0\",\"t\":{\"14622130_10\":1526918954,\"14622130_1\":1579629276},\"r\":{\"expt\":\"23:59\",\"type\":1,\"ov\":1},\"tpls\":[]}",
As this is not documented and I understand that it can change at any time, I ask for your collaboration, indicating in detail what each element of the response represents, there are some that are relatively easy to guess, but there are others that are very specific, I have been deciphering them to test and error, however it takes me a lot time, so again I make the request so that they can support me with the documentation or something like that.
Regards.
Regards.
